HIGH IDEL
Old Apr 20, 2016 | 07:07 PM
senior bear's Avatar
HIGH IDEL
HI picked up an 88 firebird with a 305 tbi on cold start up she idles around 1500 rpm then slowly drops to 550.found a split vac hoze changed it idle sat at 550 .left car went back to it started idle 1500 rpm car has dun 65 miles last year .do you think a tbi rebild and change vac pipes etc or am i barking up wrong tree ?
Old Apr 21, 2016 | 03:56 AM
Schurkey's Avatar
Re: HIGH IDEL
Define "cold".
1500 rpm cold idle as a fast-idle isn't so far off.
Old Apr 21, 2016 | 05:48 AM
Re: HIGH IDEL
cold left over night .outside temp 12c 53f
Old Apr 21, 2016 | 04:11 PM
Schurkey's Avatar
Re: HIGH IDEL
OK, that seems too warm to require 1500 rpm fast idle. I'd be looking at the scan tool to see what the commanded idle speed is, what the idle speed actually is, and whether the IAC is responding properly--and assure that the IAC passage isn't covered in carbon and slime.
Old Apr 22, 2016 | 02:48 AM
Re: HIGH IDEL
THANKS can you recomend a scan tool hear in the uk scan tools dont even list pontiac ! even the snap on scan tools dont list it.so ill have to inport one thanks for yore help i shall have a look at the iac and see whot condition its in the car has dun very few miles in last 5 years between its mot last year and this year it did 65 miles !
Old Apr 22, 2016 | 11:47 AM
Schurkey's Avatar
Re: HIGH IDEL
Or just buy the software cartridge from the USA, and install it into a local Snap-On scan tool.
Old Apr 23, 2016 | 06:36 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: HIGH IDEL
If you have a laptop can get an ALDL interface cable and use WinALDL (which is free).
RBob.
Old Apr 23, 2016 | 08:41 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Re: HIGH IDEL
RBob.
I had forgotten about this option. Read up on it a little bit a few years back. Of late, I've been keep an eye on auctions for older OBD I scanners. Sounds like this might be the better way to go.
Does this duplicate functionality in the EBL Flash?
Old Apr 24, 2016 | 07:14 AM
fokeyman's Avatar
Car: 89 IROC
Engine: l98 350 TPI
Axle/Gears: 373s
Re: HIGH IDEL
I did this with http://www.ebay.com/itm/231227363471?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT. In an L98. Soldered tx+rx to one wire, ground to ground. Had a 10k resistor sitting around that I had to jump ALDL pin A+B with. Tossed on a usb cable and I used TunerPro and can see what's going on in that ecm.
Edit: Wow, that's a big picture instead of just a link, sorry.
Old Apr 24, 2016 | 08:16 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: HIGH IDEL
No, the EBL products have a dedicated high speed interface. The ALDL is still active, but the EBL system doesn't use it.
RBob.
Old Apr 24, 2016 | 11:34 AM
DynoDave43's Avatar
Re: HIGH IDEL
RBob.
Perhaps I should ask that differently. If I have EBL, do I need to be able to read codes? Or is everything I need for troubleshooting in the interface?
Old Apr 24, 2016 | 11:45 AM
DynoDave43's Avatar
Re: HIGH IDEL
Originally Posted by fokeyman
I did this with this. In an L98. Soldered tx+rx to one wire, ground to ground. Had a 10k resistor sitting around that I had to jump ALDL pin A+B with. Tossed on a usb cable and I used TunerPro and can see what's going on in that ecm.
Interesting...I'm going to go do some reading.
Old Apr 24, 2016 | 12:04 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: HIGH IDEL
Not separately, the codes are available via blinking the SES/CEL or just looking at the What's Up Display (WUD):
http://www.dynamicefi.com/EBL_Screen...es/wud_000.jpg
The above image is part of this page:
http://www.dynamicefi.com/EBL_ScreenShots.php
It shows much of the EBL's WUD capabilities (and a decent tutorial on it as well). Be sure to see the "Diagnostic Display. . ." screen shot.
RBob.
Old Apr 24, 2016 | 12:13 PM
DynoDave43's Avatar
Re: HIGH IDEL
Thanks RBob. I had forgotten about that...I read all through the site when I first bought my car.
Old May 1, 2016 | 03:49 PM
Re: HIGH IDEL
HI ALL fited new iac today fixed hanks for the advice schurkey
Old May 2, 2016 | 02:13 AM
fokeyman's Avatar
Car: 89 IROC
Engine: l98 350 TPI
Axle/Gears: 373s
Re: HIGH IDEL
Good deal, glad you're up and running.
86ZRESTO
May 21, 2018 08:33 AM
Schurkey
Apr 8, 2016 12:38 AM
IROC AND ROLL
Mar 29, 2016 09:52 AM
thebossmanscot
Mar 27, 2016 11:11 AM
azcamaro
Mar 23, 2016 07:24 PM
