O2 conversion
Old Jun 7, 2016 | 07:01 PM
Steven9773's Avatar
O2 conversion
So this is my first time posting here I've searched around trying to find info on this and none of the post had what I was looking for. I'm using the Tbi and Ecu off a 94 1500 with a 350 to do a DIY fuel injection on a small block dodge I'm building. It is my understanding that these systems use a narrow band o2 sensor and don't fine tune the afr they just alternate between lean and rich. Is there a way to convert them to wide band and set them up to make actual adjustments to it for better power and mpg?
Old Jun 9, 2016 | 03:11 AM
Schurkey's Avatar
Re: O2 conversion
The OEM system DOES fine-tune the AFR, by bouncing between rich and lean--as all computer-controlled systems do when fine-tuned by an O2 sensor. The fuel trims are short-term and long-term.
The issue is that there's a limited range of adjustability, not that there isn't any range.
One of the guys on this forum sells a tuning kit (EBL) for the TBI computers. Search this forum for EBL and be prepared for a lot of hits.
perZ
Jun 15, 2016 09:17 PM
IROCZ1989
May 25, 2016 05:50 AM
bubbaz28
Carburetors
May 20, 2016 03:42 PM
Dartht33bagger
May 17, 2016 01:21 PM
