Possible Vacuum Lines Missing???
My 89 RS 305 TBI Has a Random Hissing Sound When the Car is Running Pop the Hood and U Hear it Hissing Cant Tell Where its Coming from but as the Car Warms Up and Drives It Goes Away After its Running you still Hear it Just not as Much when the Car is Warm and Idle Drops to about 900Rpm (Normal) But can Anyone give me Info Where to Start Looking And what to Becareful Of Thanks
Re: Possible Vacuum Lines Missing???
Iac passage and cold higher iac position.
Idle air control
Car: check
Engine: check
Transmission: check
Round thing protruding from the right hand side of the TBI unit. Has a square 4-wire connector on it. Note that the hissing is normal, with the stock air cleaner it can't be heard.
RBob.
RBob.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
I have the same hissing sound with my tbi since I've had an open element air cleaner. Sounds a little alarming, but it's ok, and it runs very well.
