Fuel pressure
Old Feb 19, 2018 | 06:46 PM
Jplum's Avatar
Fuel pressure
Ive got a 1988 chevy c3500 with the 350 tbi anyone know what the proper fuel pressure should be?
Old Feb 20, 2018 | 01:02 AM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
Axle/Gears: G80 3.23
Re: Fuel pressure
also go here
http://www.pacificp.com/forum/index.php
http://www.gmt400.com/
Old Feb 20, 2018 | 10:35 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Fuel pressure
12-14
From your other thread
Originally Posted by Jplum
Fuel pressure is good
Old Feb 20, 2018 | 05:19 PM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
Re: Fuel pressure
I've got a video somewhere where I was starting up and driving around my truck on 7 psi, barely.
Old Feb 25, 2018 | 02:27 PM
Schurkey's Avatar
Re: Fuel pressure
I thought 9--13 psi was the GM spec.
Old Feb 25, 2018 | 04:26 PM
Jplum's Avatar
Re: Fuel pressure
12 is what a 350 tbi is supposed to run
Old Feb 25, 2018 | 10:43 PM
Schurkey's Avatar
Re: Fuel pressure
I jacked-up my '88 K1500 from 10 to 11.5 psi with no apparent change in driveability.
Old Feb 26, 2018 | 02:30 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Re: Fuel pressure
Stock GM regulator on the 1992 G20 Van I pulled the 350 out back in the day was running 14 psi. Have found the as installed pressure anywhere between 9.5 ps and 15 psi. In my experience the ones that were in the 13-14 psi range with a STOCK engine ran best.
Old Feb 26, 2018 | 07:18 PM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
Re: Fuel pressure
I bet what happened is someone in the past did a TB rebuild and used the POS regulator spring that comes from the parts store instead of the factory one. Parts store = flingy and loose, Delco = strong and stiff
hectre13
Sep 11, 2006 03:08 PM
