Mild 350 TBI build need some help/advice
Old May 4, 2018 | 05:19 AM
Ridge06's Avatar
Car: 1991 k1500 and 1992 k2500 6lug
Engine: Stockish TBI (350hp)
Axle/Gears: 3.42 for now, 3.73 soon
Been a mechanic for years, military, still learning most of this stuff for my TBIs. I know a fair amount, enough to keep them, this is my first built one. My understanding of the fuel and air and all the numbers is a bit slacking. That's why I'm here.
345-350hp 1991 k1500 currently stock 3.42 (will be 3.73 posi once engine is set)
350 block stock pistons double roller timing set
-headers dual to Thrush welded
-186 heads
-edelbrock 2102 cam
-edelbrock 3704 Intake
-stock throttle body with adjustable FPR, unsure of injector lb. (RIN1001/1020 and 1032) red tips with faded yellow center, whatever that means. (Picture)
-open air element setup
-transmission is 5speed manual
-stock fuel pump until I find a suitable DIRECT replacement for it
**** I also have a Harris Performance chip installed built for a 91 suburban with flat top pistons a bigger cam and ported stock tbi heads and intake***
Currently it starts up great, idles where it should cold and idles as it should until warmed. Throttle is good to 3500rpms, no issues. Once I drive, my issues are:
1. When coming to stops or holding clutch in (coasting) the idle gets too low, more so the longer I drive it, and has even died on me.
2. When I'm cruising around 20mph or 30 or 40 (have not taken on the highway yet) and I want to take off in the same gear it slightly wants to cut back or bog and also pops the smallest amount.
My FP is at about 11 right now which is low, I should be closer to 14 or 15 but I'm currently waiting on the pod gasket since I broke it. Once fixed i can see where my adjustment went to. If I am cruising at 20-25mph and stick it in 4th and go WOT it seems like the fuel pump is keeping up about 98% give or take.
Basically just looking for some input on similar builds and input on the pictures if I'm able to show them after typing all this. I appreciate any help in advance.
update: uploading pictures works but is funky so bear with me. Also, I've edited the build list slightly.
Old May 4, 2018 | 06:20 PM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
Axle/Gears: G80 3.23
Re: Mild 350 TBI build need some help/advice
My truck acted the exact same when it was TBI and had 11psi. Then i fixed the regulator and all went good. So maybe fix that and then report back
Old May 5, 2018 | 07:51 PM
89-S-dime's Avatar
Engine: 350 TBI build
Axle/Gears: 3.73 G80
-186 heads
-edelbrock 2102 cam
345-350hp ?
Old May 8, 2018 | 02:05 PM
6998poncho's Avatar
Car: 1998 Firebird Formula M6
Engine: LS6 installation finished 8-17-2011
Axle/Gears: Stock 3.42 Ratio
-186 heads
-edelbrock 2102 cam
I'm wondering why you would try to floor it at 20-25 mph in 4th when you're way below the powerband of the engine. Not really a valid test IMO. I'd drop a gear or two and rev it out. Since you have mods beyond the stock parameters have you tried to drill out the plug on the throttle body and adjust the idle with the adjusting screw behind the plug? That might be an option to try.
Old May 9, 2018 | 12:30 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Your problems are due to the chip. You need to datalog and custom burn a chip for the combo you have. Anything else is just chasing parts. These cars will not run well with TBI mods (either through parts or displacement) without custom tuning.
Old May 10, 2018 | 05:29 PM
Ridge06's Avatar
Update:
I adjusted my FPR 4.5 times which got me to 13.5psi. It seems to be a little better for it, but hard to tell. The only problem I'm having now is when I go for a drive and on the way home every stop I get to basically almost kills the engine because the rpms get way too low. I can sometimes downshift to slow myself down, and even use 1st only because I do it at very slow speeds but it keeps it from going too low of rpms if I can get on the gas again to go. So when I actually get home and have to turn into my slightly inclined driveway that's where it gets low enough to shut it off and it has twice now out of a small handful of times. Fuel pressure is staying at 13-13.5
Old May 11, 2018 | 01:28 PM
Schurkey's Avatar
What is the data stream showing?
What is the commanded idle RPM? What is the actual idle RPM? IAC active?
Coolant temp?
O2 sensor readings?
EGR working properly?
When was the last time this thing got a compression test, distributor cap 'n' rotor, plug wires and plugs?
Old May 11, 2018 | 05:30 PM
Ridge06's Avatar
So even though the chip is tuned for another very similar build, without having it tuned for mine specifically then that's where my problem could be?
Old May 11, 2018 | 05:40 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
The only way to tell is datalog. I have seen a shady trick done in Harris tunes setting the min/max of the int and blm to 128 so it looks as if the tune is perfect.
Old May 11, 2018 | 05:42 PM
Ridge06's Avatar
Coolant temp?
O2 sensor readings?
well with it all being new, yes I do need a new distributor but it is working fine it's just used, I know all the sensors and other components are working properly yes. I'm not sure what you mean by "commanded idle rpm", could you elaborate more? The idle is about 600 give or take 50 when normally idling, and its smooth. The idle starts put around 1100 in cold start and slowly drops to that 600ish when fully warmed. I can sit in the truck and rev it with no problems, I can drive it with no problems up until I'm coming to a stop. Fuel pressure stays the same through and through even when its idled way down when coming to the stops. I feel like maybe my injectors maybe aren't the right ones or maybe my pump isnt the greatest or maybe the chip is further off than I thought or maybe my old distributor could be throwing it off just a little. I'm also thinking maybe my transmission is getting to be toast. I'm not familiar with the nv3500, I'm more of a 700r4 kinda guy, but with a new clutch it still may be too worn inside. I think maybe once I get the 3.73 locked axle under it and get the chip burning stuff from my buddy I'll have decided to put my rebuilt 700r4 under it and maybe everything will fall together at that point. I should be able to tune it myself via the chip if the burn isnt close enough to my build, and I absolutely believe the 3.73 will help a lot but if I cant get the tuning checked out then I could be chasing my tail.
Old May 11, 2018 | 05:47 PM
Ridge06's Avatar
Ok so I need to just get the datalogging stuff from my buddy and see what the chips at? So another thing to throw in is it smells a little rich when warming up and more rich when fully warmed, now wouldn't adding fuel pressure just make it run more rich or would the added fuel pressure tell the computer to lean it out due to the added fuel pressure? Or neither?
Old May 11, 2018 | 06:01 PM
Engine: Lb9
Transmission: M20
The added fuel pressure would richer up the mixture.
Here is the $42 adx to datalog with tuner pro rt. The ecm will try to pull fuel in closed loop.
http://www.gearhead-efi.com/Fuel-Inj...Information-42
Old May 14, 2018 | 11:19 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Yes. Mail order tunes are like mail order surgery. The Dr. needs to have the patient in hand.
Old May 16, 2018 | 10:25 PM
Schurkey's Avatar
Connect your scan tool.
What RPM is the computer trying to achieve (commanded RPM)? What is the actual RPM? A difference indicates a problem with the IAC, wire harness, or ECM, or indicates a mechanical problem such as a vacuum leak.
Don't forget about the other items:
Coolant temp?
O2 sensor readings?
tmmilas
May 3, 2011 04:38 PM
leftyblitz
Theoretical and Street Racing
17
Sep 10, 2010 07:08 PM
1985bluecamaroz
Jul 26, 2004 01:25 PM
POS Camaro
Oct 26, 2002 08:03 PM
