1990 TBI/Auto Code 32 after Header/exhaust install
Old Jun 4, 2018 | 11:45 AM
rt66er's Avatar
Car: 1990 Pontiac Firebird Formula
Engine: L31 350 TPI
Transmission: Tremec TKX
Axle/Gears: 3.23 Posi
Ever since installing a set of Hooker headers and full exhaust (cat delete), I get a code 32 after 15-20 minutes of highway cruising (60-70 mph). Didn't get check engine light before exhaust install and I have read a few "comments" that decreased back pressure can trip a code 32 on SD TBI. Is this true? Anything I can do to prevent this?
Old Jun 13, 2018 | 12:46 PM
Ibazzabar92's Avatar
Car: 1992 RS/89 Formula
Engine: 305 TBI/350 TPI
Transmission: auto
Axle/Gears: 2.73/3.08
Re: 1990 TBI/Auto Code 32 after Header/exhaust install
this is a common occurrence
Old Jun 13, 2018 | 03:25 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
You are correct about the exhaust back=pressure. There are three different types of EGR valves, positive pressure, negative pressure, and neutral pressure.
Changing the valve from the current type to one of the others should clear up the malfunctioning EGR.
RBob.
Old Jun 13, 2018 | 03:31 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
RBob.
I did not know that. Very interesting. How does one ID one from another? Any common substitutes used in this scenario? Like '92 G-van or some such?
Old Jun 13, 2018 | 03:35 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
The egr usually has a letter on it to identify if it’s p or n pressure.
Old Jun 13, 2018 | 05:58 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Yes it is ...
To fix it you need to drill the hole in the EGR valve a few thousands to allow more vacuum to the valve to make it open. Don't go too much or it will cause problems (stumble).
Old Jun 13, 2018 | 06:08 PM
rt66er's Avatar
Engine: L31 350 TPI
RBob.
Thanks. Is this technique verified? That would be great if it's that simple.
Old Jun 13, 2018 | 06:10 PM
rt66er's Avatar
Engine: L31 350 TPI
Originally Posted by Dyno Don
Yes it is ...
Is the hole you're referring to where the vacuum line attaches?
Old Jun 16, 2018 | 11:25 AM
rt66er's Avatar
Engine: L31 350 TPI
Does anyone know whether the SD TBI EGR is positive or negative? I have read differing specs. I think I see an "N" on mine, but the one RockAuto specs is a "P".
89RedFormula
Apr 18, 2018 10:03 PM
pearl_iroc
Jul 5, 2007 11:04 PM
DarkRS91
Apr 8, 2007 07:39 PM
rnoftz
Jun 1, 2005 09:49 AM
iroc_cragg
Jun 2, 2003 02:10 PM
