Fuel pump time
Old Aug 9, 2018 | 12:36 PM
draco's Avatar
Car: 1992 Camaro RS 25th Anni.
Engine: 5.0l TBI
Transmission: 700R4 Automatic
Axle/Gears: 3.73 Gov lock
Fuel pump time
I have a spare TPI setup in my garage. Eventually my TBI may go TPI.
Can I use the TPI fuel pump without any additional changes or do I need to regulate it down for the TBI?
Old Aug 9, 2018 | 12:41 PM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
Axle/Gears: G80 3.23
Re: Fuel pump time
Supposedly its not that big of a deal. I did it in my truck for a few miles before going TPI. You'll just have a ton of fuel returning to the tank lol
Old Aug 9, 2018 | 07:57 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Fuel pump time
Its fine. The stock regulator will do the regulating. The excess will simply go back through the return line.
Old Aug 10, 2018 | 02:08 PM
Schurkey's Avatar
Re: Fuel pump time
Far as I can tell, the TPI pumps and the TBI pump produce about the same volume, the difference is the pressure. The pressure regulator on the TBI will provide proper pressure for the TBI injectors.
I've been running a TPI pump (EP241) on my K1500 for years.
https://www.thirdgen.org/forums/tbi/...p-upgrade.html
kowboy59
Nov 7, 2011 09:36 PM
Twilightoptics
Nov 18, 2002 01:26 PM
BuckeyeROC
Apr 29, 2002 07:18 PM
makinemtap
Jan 30, 2002 01:09 AM
442guy
Apr 13, 2001 04:58 PM
