Tbi problem please help
Old Jun 12, 2019 | 07:49 PM
Mouaz Al Baba's Avatar
Hello everyone this is my first time here! I own a pontiac firebird 1991 v8 -305 tbi recently i started to face a very annoying problem, i can't accelerate my car everytime i step on the gas pedal the rpm goes to 3k and then it chokes up, ive changed the MAP but the problem still the same, even though i removed the catback and put a straight pipe, and left the air line hanging.
one thing if the car is on parking or neutral and i rev slowly i can get the RPM high.
I tried to attach the videos but it kept saying its not supported.
Please if anyone can help.
Thanks in advance
Old Jun 12, 2019 | 07:52 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Tbi problem please help
Any stores codes ?
Have you checked base timing and fuel pressure ?
Old Jun 12, 2019 | 09:58 PM
Schurkey's Avatar
^^^ Yes.
Fuel pressure test preferably under load--when the engine is acting up.
Connect scan tool to view data stream and read "codes".
Verify "usual" maintenance items--Fuel filter not plugged, air filter not plugged, spark plug wires including coil wire in good condition, Distributor cap and rotor in good condition (Specifically verify the carbon button in the center of the cap!) Spark plugs not excessively worn, etc.
Old Jun 17, 2019 | 11:31 AM
navy02ws6's Avatar
Engine: LS1, LB9, L03
You say you removed the catback and put a straight pipe...just wanted to confirm that you did try removing the catalytic converter as well to see if that's plugged and causing the problem.
Old Jun 18, 2019 | 02:51 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
timing, pressure, injectors would be my short list of items to test. How is the fuel filter/air filter?
You didn't delete the 02 sensor did you when you were doing the exhaust work?
Old Jun 18, 2019 | 11:49 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Originally Posted by navy02ws6
................. the catalytic converter as well to see if that's plugged and causing the problem.
+1 for a plugged cat.
Chris_89rs
Mar 27, 2012 12:59 PM
chevyv8guy
Sep 26, 2010 11:42 AM
slowboy43
Aug 17, 2009 11:39 PM
BillD91RS
Mar 6, 2003 03:11 PM
chuck6860
Jul 23, 2002 09:36 AM
