Idle issues.
Old Aug 25, 2019 | 04:04 PM
Dfdub92's Avatar
Car: 1992 Camaro R/S
Engine: Stock 305
Transmission: Stock
Axle/Gears: Stock
Idle issues.
When I start my car it idles up and down, down to a point it almost dies. This started happening all of a sudden out of no where. I changed the coolant temperature sensor, tps, pickup coil, ignition module, coil pack. And none of that helped the IAC is some what new I just don’t remember when I changed it. I don’t want to keep buying parts I don’t need because it’s getting expensive. I’m posting a video of my car doing it. If someone had this problem and fixed it please let me know what you did... please I want a response from someone that had the same issue and fixed it.
Last edited by Dfdub92; Aug 25, 2019 at 04:07 PM. Reason: I don’t see my video attached
Old Aug 25, 2019 | 04:37 PM
tealman92's Avatar
Car: 1992 Z28
Engine: 383
Re: Idle issues.
Surging issues with tbi is common. Could be a few different things. You can test for each one. Check your injector spray pattern. You might have a leaky injector or sticking injector. Your fuel pressure regulator might need to be rebuilt. How old is your fuel pump? Last time you changed the fuel filter? Check your egr valve. On my 92 rs I had a long time ago the surging was from 1 sticky injector and a failing fuel pump. Check these area and report back. Also do a search for tbi surging.
Old Aug 25, 2019 | 04:46 PM
Dfdub92's Avatar
Engine: Stock 305
Transmission: Stock
Axle/Gears: Stock
Re: Idle issues.
I was in the process of rebuilding tbi it self, I got a little hot in the garage. But that’s what I was trying next. I try the others as well.
Thanks.
Old Aug 25, 2019 | 08:29 PM
Schurkey's Avatar
Re: Idle issues.
Connect a scan tool, investigate the data stream.
Verify fuel pressure. Verify all the "tune up" stuff is in good condition--ignition, fuel delivery, compression, exhaust.
rongi3
Aftermarket Vendor Review
Mar 13, 2017 05:07 PM
chadzeilenga
Mar 27, 2012 08:12 PM
Destructimus
Dec 26, 2008 12:23 PM
walts_Restorati
Sep 2, 2008 10:18 AM
ADMZ24
Jan 30, 2001 01:45 PM
