350 swap, need tuning advice
Old Sep 23, 2019 | 12:16 AM
Bubbajones_ya's Avatar
Car: 1998 Viper/1996 Bronco
Engine: 8.0/7.3
Transmission: T56/ZF5
I don't mean to be a double dipping but I figured I'd ask in this section as well since it pertains to TBI as well as ask in the prom section for my issue.
Backstory, I found a 350 from a 1999 yukon in a junkyard about 4 years ago. I was getting ready to throw it in my Camaro when I found the first 7.3 I put in my Bronco was bad. Well almost immediately after fixing that, I got a call from my recruiter that I'd be heading off for basic. Fast forward two years after that and I finally got around to putting that 350 in my Camaro. I just finished bolting everything back up but the car really doesn't want to run well. I did manage to get it to stay idling for the most part (sometimes still dies), but it really wants to die if I try moving it. I suspect some of my issues may be coming from me setting the valve lash too tight, since I tried adjusting it when the motor was out and cold, but I know that can't be everything.
My current setup:
350 with 062 vortec heads
Edelbrock performer manifold with TBI adapter plate
#61 injectors set at 25psi
hooker 2055 headers with y-pipe an 3" exhaust
elgin 1136 cam (210/215 @ .050, .462/.470" lift and cut on a 110* LSA advanced to a 106* ICL)
EBL tuneable computer
I'm basically useless with tuning, so I don't know my best course of action to take on getting this driveabe. I tried using my old tune and adjusting some values, but it wouldn't idle at all with that.
With my old tune on the 305, I had the same camshaft/exhaust (re-used it in this motor). Are there any tables I can use (copy/paste) to my new bin that will work with the 350? Or does the configuration of the heads/motor change too much that everything has to be heavily edited? (You can maybe tell I don't know what I'm doing with tuning)
I figured that since I have the same camshaft, the valve timing would be the same so some tables (like my SA tables) would be re-usable, and I could re-use a bit of the .bin file to move over to my new file, but I don't know enough about this so I could be completely off.
I took leave this week to work on our house before the miserable wyoming winter ruins my life, so I do have time to mess with this thankfully. I figured my first course of action will be to re-adjust the valve lash and see if that's what's bogging the motor down so much, but I know the tune is in pretty bad shape. Any help or advice would be greatly appreciated!
Old Sep 23, 2019 | 07:28 AM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
Re: 350 swap, need tuning advice
Pretty sure its getting too much fuel try 18psi.
Old Sep 23, 2019 | 02:22 PM
Engine: 8.0/7.3
I'll bump the fuel pressure down a bit and see if that helps! I thought I had it set to about 18-20, but when the car started to idle better, the fuel pressure gauge increased where it sits around 25 when idling.
Old Sep 23, 2019 | 05:37 PM
Engine: 8.0/7.3
I ended up setting the fuel pressure to about 19, looked over the valve lash, and readjusted timing.
I think the main problem was I had the timing way off..... I thought I had it set around 0* but it was significantly after 0.
I ended up resetting the timing to around 10* advanced and adjusted the tune accordingly and was able to drive around! However, I went to tune and use the VE learn feature, and forgot to plug back in the ESC module so I don't think all the datalogging/tuning will really mean anything since that was unplugged...
However the car is driveable now so that's good!
Old Sep 23, 2019 | 07:09 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
I would expect that setup to need ~24 psi to adequately fuel it at WOT.
Old Sep 24, 2019 | 02:12 PM
Engine: 8.0/7.3
Hmm okay I'll see if I can raise the fuel pressure again. When I had the gauge initially hooked up to the adapter (between the hard line and the rubber line near the driver's side "frame rail"), the gauge was reading around 24-26psi when the engine was running. This was when the motor still wasn't running right (timing was off) and I couldn't drive it around.
I maxed out the spring adjustment before putting the TBI back on the motor during the insallo, but I haven't touched it since. (I did the adjustable fuel pressure regulator mod) The fuel pressure seems to be staying pretty steady at 19psi since I got the timing right. I'm thinking I'll either try and look for a different spring to throw in there, or potentially look for an aftermarket fuel pressure regulator I can hook up in-line or something. I find it kind of odd that when the car was struggling to idle (since the timing was way retarded at probably 10+ ATDC when I first threw the distributor in), my fuel pressure gauge was reading around 25psi, but now that the engine is idling better and decently happy-ish, the fuel pressure is at 19psi. I can't recall if I put in a different spring in the regulator when I did the adjustable regulator mod, but I want to say it's the stock spring in there right now.
I have a future goal which I know is far from practical/easy, but I would like to attempt to throw a turbo on the motor later on down the road. This definitely would be a bit later, because I want a little better handle at tuning first obviously, and I'd need to make custom piping and a TBI "hat", so my welding will need some practice for sure as well. I have two spare 7.3 turbos (from my Bronco) that I'd like to try and plumb in and get working. I know a turbo is going to require an adjustable fuel pressure regulator and a 2 bar MAP sensor. I may just look into getting an adjustable fuel pressure regulator now that's vacuum referenced that I can plumb into where I put in the fuel pressure test port or something.
Old Sep 25, 2019 | 02:36 PM
RicerEater's Avatar
Car: 1992 Chevrolet Camaro Iroc-z
Engine: 305 TBI
Transmission: T5 T56 needs rebuild
Axle/Gears: 2.77 POSI with Disc brakes 9 bolt
If you fork over 75-100$ to a tuner on a lunch brake they may be willing to help you with a baseline to work from! And go from there. Just an idea!
Old Sep 29, 2019 | 01:19 PM
Engine: 8.0/7.3
Yeah I'll definitely look into something like that. Unfortunately, I don't think Cheyenne Wyoming has much for tuners, so I have to look at Northern Colorado for that.
jvaughn
Jul 1, 2011 10:59 AM
Grumbles
Mar 25, 2010 10:00 PM
Smellofrubber
Mar 29, 2007 09:46 AM
nolimit2game
May 28, 2006 08:39 AM
