Code 32 only in OD
Old Jul 18, 2020 | 11:19 AM
magicdave2's Avatar
Car: 1983 Pontiac Trans Am Recaro
Engine: CFI 305
Code 32 only in OD
Hello,
I've searched the board but didn't find a post that corresponded to this particular issue. I've got a 1990 Firebird Formula TBI w/ 305 engine w/ auto transmission. When I cruise on the highway using the OD setting on the shifter I'll get a Code 32 SES light after 15-20 minutes of driving. However, when I cruise at highway speeds using just the D setting the ECM doesn't trigger the Code 32 SES light.
Does that point to the solenoid being bad instead of the EGR valve? Or, is it something else?
Thanks!
David
Old Jul 18, 2020 | 08:02 PM
Schurkey's Avatar
Re: Code 32 only in OD
Find a REAL service manual, find out what conditions set Code 32 on your vehicle. Follow the diagnostic procedure.
Do you have a modified exhaust system? Some EGR valves sense backpressure.
Old Jul 19, 2020 | 10:25 PM
magicdave2's Avatar
Engine: CFI 305
Thank you for the reply! After posting, I did come across a thread that discussed aftermarket exhaust systems causing this problem. The car is new to me about two months ago. I suspect the pipes from the cat back are aftermarket. Not sure about the cat itself. I've tried to find a photo of OEM exhaust for the 90 Firebird Formula but am having trouble finding one.
Would an exhaust manifold leak also cause this code under these circumstances?
Thanks!
David
Old Jul 21, 2020 | 09:27 AM
navy02ws6's Avatar
Engine: LS1, LB9, L03
I had a code 32 on my '91 RS 305 TBI that would only show up on the highway in OD at low RPMs. EGR valve was full of carbon when I pulled it off. Replaced it 3 years ago, no problems since.
Old Jul 21, 2020 | 11:32 AM
magicdave2's Avatar
Engine: CFI 305
Did your car have the stock exhaust at the time?
Fender Engineer
Nov 15, 2013 09:33 AM
Jason1313
May 4, 2011 11:28 PM
90camaroirocz
Oct 8, 2005 09:14 AM
iggy1991
May 23, 2004 12:02 AM
85f-bird
May 26, 2002 09:03 PM
