TBI to TPI harness question
Car: 1991 Camaro RS
Engine: TBI 305
I have a 91 TBI Camaro that I am converting to TPI. I have a 91 TPI engine harness. I read somewhere that it is a plug and play swap except Two wires need changed, Does anyone know which Two they are and what to do with them, Thanks
Transmission: T-5, TH350, T-5
Re: TBI to TPI harness question
Is the harness from an automatic TPI car? I had to add the reverse light switch to the c100 connector. You'll also have to change the vss wires to bypass the speedometer buffer box to go straight to the ecm instead. I think that's it.
Car: 1991 Camaro RS
Engine: TBI 305
its from an auto car. I already T56 swapped the car so back up lights are taken care of. And I needed a Dakota digital box to make the speedometer work. It goes straight to the speedometer.
http://www.austinthirdgen.org/?pid=19 The C100 and C207 are all you need to think about. If there's any discrepancies then you'll find them there
quick90rs
May 29, 2010 08:02 AM
ttypecamaro
Jun 3, 2006 01:38 PM
