worth it to fix 305 with lifter knock before selling?
Old Feb 3, 2021 | 08:03 PM
mr.gains's Avatar
Looking to sell my 91 rs camaro but the motor has lifter knock. Im thinking of paying someone to put the summit k1103 cam and lifter kit on it to fix the knock before selling so I can get higher value. Or should I just sell as is and hopefully get someone is planning on ls swapping it and pays around what I want.for it? witch is about 2-2.5k.
car holds salvage title, has few suspension upgrades and a 01 camaro rear end I was told.
https://cimg5.ibsrv.net/gimg/www.thi...d870143334.jpg
Old Feb 4, 2021 | 10:39 AM
Schurkey's Avatar
Re: worth it to fix 305 with lifter knock before selling?
I don't think a 305 is worth fixing. Salvage title is going to make things even more difficult.
HOW do you know it's a lifter problem, and not a piston slap or rod knock or some other failure?
Old Feb 4, 2021 | 11:32 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The other issue is that Summit cam is flat tappet, while the stock L03 has a roller cam in it. So at a minimum it is a downgrade along with also requiring new push rods (different length).
Up side is that the car appears to be in decent condition, at least the front and drivers side.
RBob.
Old Feb 4, 2021 | 11:45 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Disclose to the seller and sell as is. A cam swap will not drive the value up.
Old Feb 4, 2021 | 04:44 PM
OrangeBird's Avatar
Car: 1989 Firebird
Originally Posted by mr.gains
Looking to sell my 91 rs camaro.....
Bad plan, they ain't making any more 91 Camaros these days.... (or any other third gen F bodies for that matter , dammit )
Sooo, best keep what ya got so ya don't end up as next year's incurable case of the "I HATE myself for selling that car" blues !
You can come back here in a few years when ya got it all fixed up and thank me for slappin some sense into ya
Old Feb 4, 2021 | 05:04 PM
mr.gains's Avatar
No clue its ticks while in neutral or at a stop.
Old Feb 4, 2021 | 05:14 PM
mr.gains's Avatar
I love the car but im going to boot in a few weeks and dont have a place to store it.
Old Feb 4, 2021 | 05:24 PM
mr.gains's Avatar
RBob.
Dont even know if the car is a 305 or 350 the guy I bought from said it was a 350 but my friend said it was 305 since engine looked similar to his third gen of the same year
Old Feb 5, 2021 | 07:45 AM
mikeceli's Avatar
Engine: LB9 305
Transmission: AT
If by "boot" you mean "Boot Camp" , Thank you in advance, for your service!
It sounds like you know the car has a noise, that you suspect is a lifter, but might be something else(exhaust manifold?)
Sell it and advise the prospective buyer about the noise beforehand.
Old Feb 6, 2021 | 11:17 PM
88RS's Avatar
Car: 91 z28
Engine: 305 tpi
Transmission: t5
Axle/Gears: lt1 10 bolt 3.23
I have had good results using Rislone in neglected engines with lifter ticks.
Old Feb 7, 2021 | 09:26 AM
ironwill's Avatar
Car: 1986 IROC Z
Engine: 5.0 TPI
Axle/Gears: 3.23 Posi
Too many strikes against putting more $$$ in this car just to sell it. Cut your losses; advise potential buyers of the car's issues, and let it go, as-is.
GLWS.
Shadygrady
Jun 12, 2008 01:35 PM
Chuck!
May 10, 2003 03:58 PM
V8Astro Captain
Apr 22, 2003 06:16 PM
Ken88GTA
Jun 12, 2001 01:57 AM
