HELP Low temp fan switch for 1992 camaro
Old Jan 14, 2022 | 07:11 PM
johnnyboy6961's Avatar
Hi all, hope i'm in the right location. I have a 1992 Camaro Convertible 305 TBI and it has a manual fan switch. I told my mechanic can he fix it to go on automatically at a certain temp and he told me to get a 180 degree thermostat which i did and a low temp fan switch. I can't find a low temp fan switch for TBI can someone help with this, does anyone know what part/part number/brand where i can get a low temp fan switch so can make the cooling automatic
Old Jan 14, 2022 | 07:24 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: HELP Low temp fan switch for 1992 camaro
Sw555 wells
Old Jan 14, 2022 | 07:44 PM
I don't mean to question you, but as i looked up the part, it doesn't show that it would work on a 92 camaro or say its a low temp switch
Old Jan 14, 2022 | 07:53 PM
Engine: Lb9
Transmission: M20
Old Jan 14, 2022 | 09:36 PM
i have been, i see many switches but none are low temp
Old Jan 14, 2022 | 11:51 PM
Schurkey's Avatar
What temperature do you want?
The OEMs turn the fan on at ~220 or so. That doesn't seem "low" temp to me.
Old Jan 15, 2022 | 07:21 AM
This is my situation, i told my mechanic that i wanted a tuneup on the 1992 camaro 305 and i also told him that the person i bought it from has a manual switch installed on it and i asked if it can be converted back to automatic. So he told me to get a 180 degree thermostat and a low temp fan switch so i don't know what his intensions are but i asked him why did they put in a manual fan switch and he said probably because it was getting to hot. So i'm not sure what temp it should be
RBob's Avatar
Car: check
Engine: check
Transmission: check
210 degF on, 205 degF off (Wells SW555, Standard TS-136) 3/8 NPT x 14 threads
Listed for '86-'87 Regal & '89 Firebird
RBob.
Old Jan 15, 2022 | 07:24 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Stock is on at either 228°F or 238°F, there is conflicting information on this.
You would be better off with the stock 195° thermostat.
RBob.
Old Jan 15, 2022 | 07:29 AM
The switch you mentioned would work on a 92 camaro 305 TBI and not TPI im a novice with this stuff i was looking at it and it mentioned for TPI i have TBI
Old Jan 16, 2022 | 02:15 AM
LAFireboyd's Avatar
Axle/Gears: 9-bolt/3.45
All of the switches that have been suggested will fit and work. But when you get cross-referenced results, they'll most likely just provide matches to the factory temp range, not alternative lower temp products. So just pick the one you like that somewhat coordinates with the thermostat you like.
Has the temp ever gotten so high that you've felt the need to flip the manual switch? The factory temp is high, like has been mentioned, and I'd guess the previous owner just didn't like it that high. But rather than replace the switch with a lower temp one, he spliced-in a ground wire to manually activate the fan if he felt the need. If so, then it's probable that the switch will still activate automatically, like a failsafe, should you overlook the climbing temps and not flip your switch. Of course, to test that theory, you'd have to let the temp get awfully high, so have your finger on the switch, just in case... Or just replace it, like you're talking about.
Old Jan 16, 2022 | 07:34 AM
Thanks for all the replies, like i said i'm new at all this. Not sure why my mechanic wants me to get a low temp fan switch(if they make them) not i can't find but you feel the Wells SW555 will bring the temp down to a good level. and i'm talking all the suggestion and bringing them to my mechanic
Would any of these thermostats work for this.
https://www.ecklers.com/camaro-therm...-181552-1.html
https://www.camarocentral.com/1967_1..._p/rad-105.htm
Old Jan 16, 2022 | 11:48 AM
so i was going to buy the wells SW555 fan switch and it asked for the model of my car, after entering all the information, it says this product won't fit your vehicle any other suggestions for a low temp switch
Old Jan 16, 2022 | 12:01 PM
Engine: Lb9
Transmission: M20
Read the previous posts your head hole is 3/8 npt iirc connector is the same. Although not listed it works
Old Jan 19, 2022 | 08:48 AM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
... he told me to get a 180 degree thermostat which i did and a low temp fan switch. I can't find a low temp fan switch.
Here;
https://www.summitracing.com/parts/HYP-4028
200* F On, 185* F Off...
It will work fine with the 180*F Thermostat you said you already bought...
- Rob
Edit: It's not available on Summit Racing, try Amazon...
Old Jan 19, 2022 | 08:55 AM
Engine: Lb9
Transmission: M20
I think that one is nla for quite awhile rob
https://www.summitracing.com/parts/sum-890018
change connector and install.
Old Jan 19, 2022 | 08:57 AM
Yeah I just edited my post, there might be a few lingering on Amazon...
- Rob
Edit: Meh, then just get an OE one if Hypertech has become useless;
https://www.napaonline.com/en/p/ECHF...pressionRank=1
https://www.napaonline.com/en/p/MPEF...pressionRank=2
Old Jan 19, 2022 | 06:27 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
Yes...thats because the search / parts finder searching for the STOCK regalement switch.
as long as the switch fits / functions the same, it will just ground the fan at the lower temp...you are doing something custom so it will not "match" you could even do a different swotch size with fittins / different wiring connector etc.. but thats way more work.....
Old Jan 19, 2022 | 06:51 PM
Rob, will this work with a single fan ? i don't have dual fan
Old Jan 19, 2022 | 06:54 PM
Engine: Lb9
Transmission: M20
Omg, wow simple grounding circuit for single and fuel secondary fan.
Old Jan 20, 2022 | 02:47 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
all these are about 212F on and 200 off
Ozz1967
Feb 18, 2013 08:51 PM
jaykar
Oct 5, 2005 11:18 AM
tom3
Sep 19, 2004 10:13 AM
Barry85Iroc
Aug 30, 2003 12:48 AM
92blue
Aug 28, 2002 08:14 PM
