Vacuum line connected to throttle body
Old Oct 2, 2023 | 03:36 PM
Cesarduque44's Avatar
Hi I accidentally broke a pvc pipe when I was replacing my fuel injectors. I’m having trouble finding the hose online. The pvc line connects to 4 different lines. One goes to the pvc valve and another goes to the canister.
Old Oct 4, 2023 | 01:06 AM
Schurkey's Avatar
Re: Vacuum line connected to throttle body
PVC is a type of plastic, often used for plumbing pipe. Generally white, but other colors could be used.
PCV is an emissions-control device that's been used on vehicles since the early--mid 1960's.
Many of those (fragile/brittle) broken vacuum tubes can be spliced back together with rubber hose of the proper size. Depends on how/where they break.
Old Oct 4, 2023 | 10:58 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Maybe, just maybe, if that was a 3rd gen Camaro or Firebird engine, we may be able to help. Right off it is a port injection system, not TBI.
RBob.
Old Oct 4, 2023 | 11:03 AM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
Go to AutoZone(or wherever) and buy some similar sized rubber hose (and whatever T fittings, etc. you need) and route it in place of this one. No need to buy a hardline.
Camaro2Player
May 5, 2019 02:16 AM
Shakenblake
Aug 5, 2017 09:15 PM
Rls4762
Oct 5, 2016 10:58 PM
86IROC112
Jun 9, 2015 03:27 PM
Bobby_80s
Dec 12, 2006 10:00 PM
