Have a 350 flat tappet lo5, best route to power?
Car: 1992 firebird
Engine: 5.0 lo3
I bought a 92 bird, with a lo5 truck motor in it, runs good, but it's slow.
Current mods on it as purchased
Weiland street warrior intake
Open element filter
Stock manifolds into a unknown diameter straight pipe
Block is a 638, and 193 heads, motor is not drilled and tapped for roller
I want to ditch the tbi, put a carb on it.
I'd like to put a cam in it, along with headers into a 3 inch exhaust
car has 3.42 gears in the rear with fresh rebuild 700r4
Open element filter
Car: 1982 MSE, 1988 S10 Blazer
Engine: 305 in both!
Transmission: 200c / Th700r4
Axle/Gears: 3:73 / 3.42
Re: Have a 350 flat tappet lo5, best route to power?
Aren't the 193 heads the "swirl" port style? They run out of wind at about 4500rpm. The 3:42 and 700r4 is a GREAT combo. Your block probably has bosses for the retainer and spider for a roller cam. If it were mine I would install a roller cam and some Vortec or other decent heads. Those 2 items will make a HUGE difference in the way it runs.
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
I second 3.42s a good gear for general use with a t700
193s are swirl port,but not as bad as is often heard for use up to ~ 5500 on mild street engines. The truck LO5 can have dished or flat pistons,depending on capacity class of the truck it came from-possibly smaller valves on heavier duty engines too.
193s are swirl port,but not as bad as is often heard for use up to ~ 5500 on mild street engines. The truck LO5 can have dished or flat pistons,depending on capacity class of the truck it came from-possibly smaller valves on heavier duty engines too. Joined: Mar 2014
Car: 89 Firebird
Engine: 355 TBI
Summit K1103 or K1104 if you get a spring kit for the heads .Ofcourse swapping to Vortec heads would be great but you can get a lot more power out of the L05 with cam, exhaust, carb..etc.
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Swap the heads and put a roller conversion cam in it. Would need more info on what pistons are in the motor and what your final goals are before choosing the cam and heads
Car: 1983 G20 Chevy
Transmission: 4L60
I had a couple of swirl port head engines with flat tappet cams years ago. I liked the old Crane 272H10 in them. Lunati makes an almost identical cam that works well too.
Headers, full exhaust and a cam like this one really wakes up a 305 or 350 without being too radical for junky vacuum assisted power brakes and ac. The stock swirl ports will make a lot more power than most give them credit. I am also not a fan of carb swapping. The TBI can also make a ton of power while keeping more reliability and drivability. An EBL flash and a big block TBI unit are a lot cheaper than a vastly inferior carb swap. I put a RS in the 11s with a TBI fuel injected 305.
https://www.lunatipower.com/high-eff...k-268-268.html
There is no "L" in Weiand.
Probably a mistake.
Headers, high-flow catalyst, and larger-diameter mandrel-bent exhaust tubes into and out-of your favorite muffler. "I" would use a large-diameter single exhaust rather than screwing around with "dual" exhaust.
Vortec heads will all but eliminate any chance of using EGR; it's possible but really, really inconvenient. Also, he'd have to drill the right cylinder head (I'd drill both heads so it doesn't matter which head gets installed on which bank) for coolant bypass provisions on the TBI block; and most Vortec blocks aren't drilled, either--so no coolant bypass even if the hole is popped into the cylinder head. SOME Vortec blocks do have the bypass holes drilled; and those blocks often have 4-bolt mains and fuel pump provisions also.
Thank you.
Downside is the difficulty in tuning the TBI computer. There ARE solutions, though.
Car: '82 z28
Engine: L83 5.7
i think my 1991 G30 box truck has the deep dish pistons ~8,5 CR 190 hp
Car: 1983 G20 Chevy
Transmission: 4L60
Car: '82 z28
Engine: L83 5.7
I thought the G30 had a cam similar to a 929 since it sounds about the same as my 350 '73 1 ton dually
that engine has 993s with small 1,72 intake valves The G30 has a very heavy duty cooling system with big 4-core radiator: oil cooler in left tank,tranny cooler in right tank.
that engine has 993s with small 1,72 intake valves The G30 has a very heavy duty cooling system with big 4-core radiator: oil cooler in left tank,tranny cooler in right tank. Joined: Jan 2005
Car: 1983 G20 Chevy
Transmission: 4L60
that engine has 993s with small 1,72 intake valves The G30 has a very heavy duty cooling system with big 4-core radiator: oil cooler in left tank,tranny cooler in right tank.I have an aluminum dual core replacement that is dimensionally the same as your older 4 core in my 87 G20 with a ~380 hp L31 350 in it. Radiator manufacturers claim the dual core design sheds even more heat because the larger tubes have more surface area. Runs cool as can be with an 11 bladed plastic fan. I ended up using replacement oil cooler hoses for a 99 Tahoe and they fit pretty well. The van ones are unobtanium now.
I converted to the L31 accessory brackets and accessories. The TBI PS pump bolted right on the vortec bracket. I swapped to a 145a AD244 alternator and upgraded some of the wiring from that crappy junction post behind the battery. Proflow 4 injection with a new Vortec pump on a new sending unit in a new tank. Upgraded from the 22 gallon tank to the 33 since I was buying new components anyway and it only required another $15 in new mounting straps. The 33 gallon tank was a few $ less so it was a near wash. Gave the old pig a new lease on life. The Hooker 2.5" manifolds fit like a glove, but I wish I had gone with headers instead. One of the things I actually like on this 87 is it has the 3L80 aka Turbo 400 with a TH350 output shaft and a 3.08 gear for screaming down the interstate.
https://youtube.com/shorts/q6WOUPrYwDg?si=C0ubl_LuZDWRqxgF
Car: '82 z28
Engine: L83 5.7
Noted that '99 Tahoe oil cooler lines fit .I saw the fan in the AC post-i have a couple of those in spares stash,1995.5- 2004 S-10 4.3. my G30 box truck has the 4l80E-one of the first of that transmission.
Ghettobird52
Jul 8, 2010 02:46 PM
