TBI throttle blade closed set point
Car: K1500
Engine: 305 TBI
Transmission: TH400
Axle/Gears: 14 bolt-9.5/3:42 tru-trax locker
1988 throttle blade set point in terms of open When closed. Is there a thousands or a gauge wire that can be fitted in there for a good starting point or is it all based on counts
JC
JC
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: TBI throttle blade closed set point
I’ve always set to minimum idle speed with iac commanded in, or set engine warmed up iac steps to 20-25.
Car: K1500
Engine: 305 TBI
Transmission: TH400
Engine: Lb9
Transmission: M20
