TBI Setup - Critique Me!!!
Old Jan 24, 2002 | 08:03 PM
TP355Z's Avatar
Car: 1988 Camaro SC
Engine: LT1 SBC
Transmission: LT1 T56
Axle/Gears: 3.73 Moser 12 Bolt
Hey guys - I've just successfully dropped a 355 into my formerly 305-TBI Camaro, I've got the Holley TBI unit and a few other toys on it, i'm wondering if you experts could gimme some suggestions as to what would be good to add. THANKS!
TP (17yrs old / HS Senior)
1988 IROC Camaro
355 (.030 over / forged pistons / powdered rods / balanced)
1.94/1.50 late-model heads / ported / polished / port matched
Holley 2" Bore TBI Intake
Crane Compucam (440/454 lift) (212/218 dur)
~10:1 compression
Edlebrock TPS Headers / Y-Pipe
3" in / out high flow cat
Open Moroso 3" Element
The electrical system is stock right now - i'm looking at a new coil setup
New Year One Interior (Carpet/Headliner/Kick Panels ect...)
Grant Steering Wheel
Trans-Am Racing Seats (I'm looking for a cover kit - HELP!???)
1 1/2 inch Eibach lowering kit
KYB Shocks
700-R4 Tranny
*I'm guessing the motor is around 330hp b/c it was rated at 270 when i tore it apart (it came out of a boat) and the cam I put in was a little bit higher w/lift and duration (I ran the numbers)
THANKS FOR THE FEEDBACK!!!!
PS - How's this sound for a lisence plate "PNY KLR" ?
Old Jan 24, 2002 | 08:23 PM
Nate Hanson's Avatar
Just wondering how much it cost you do to the heads?
nate
Old Jan 24, 2002 | 08:52 PM
TP355Z's Avatar
Car: 1988 Camaro SC
Engine: LT1 SBC
heads
Um...this is kinda unfair, but I worked at a machine shop in town for 1 1/2 years - during which i built my motor. So I magged/cleaned/buffed/ported/polished/matched/cut (the valves/seats) all myself. I'm probably certain you don't think a kid could do all of this - but i had some really good tutors (sp?). I even balanced the rods/pistons and assembled it myself - so I've got my head into the car for more than exhaust tips and chrome. Any other questions u can fire away. Oh yea, I also put in brand new valves and used different springs - the stock equipment was junk. Hope this helps some...
TP
Old Jan 24, 2002 | 09:23 PM
NJ SPEEDER's Avatar
sounds like a strong combo. your hp guesstimate should be in the right ball park. i would look toward a little more cam in the future, the 350 can handle it. is that cam a roller or flat tappet?
later
tim
Old Jan 25, 2002 | 10:58 AM
r90camarors's Avatar
Car: '91 t-top RS; '91 hrdtp Z28
Engine: LO3;383tpi
Transmission: 700r4;very nice 700r4
Axle/Gears: 4.10 zt posi, 3.70 auburn
Lisense plate
PNY KLR- Sweet!! You should do it. Sounds like you engine should hold up to it. Just stay away from those damn Saleens!!
Old Jan 25, 2002 | 12:04 PM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
Your setup sounds just like mine. Mine even came out of my boat too. Same hp and everthing. I just haven't swapped mine. How do you like that cam, cause its the same one that I've been considering getting? How was the install. There souldn't be much fabrication from what I can tell?
Old Jan 25, 2002 | 01:26 PM
TP355Z's Avatar
Car: 1988 Camaro SC
Engine: LT1 SBC
well...
There wasn't much fabrication - but there were some obstacles:
1) The EGR (I used one off a 1985 IROC 305) didn't fit under the TBI. I had to use a 1 to 1 1/2 inch spacer to get it to clear and even then it was a little tight
2) The TBI Unit (Holley) had to be rewired into the cars harness - just follow the directions they give you and you're all set
3) The stock cruise/tv cable/throttle bracket didn't fit the Holley intake - so i have no cruise right now (I used the bracket holley provided)
4) The Edlebrock headers were a snug fit where the Y-pipe bolts up, they took a little prying to get into position perfectly
The Holley intake was the biggest pain I encountered - just be patient with the brackets and mounting the coil (just TRY to find 2 bolt holes on the intake that match ) and you'll be ok.
TP
Old Jan 25, 2002 | 05:07 PM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
Yea, that Holley is a bugger to get on.
Sounds like a good setup! You gonna get her to the track soon?
Old Jan 25, 2002 | 08:09 PM
TP355Z's Avatar
Car: 1988 Camaro SC
Engine: LT1 SBC
Track
This is my schedule (remember, i'm graduating this year and going into college so....)
This month - March: Get the car ready for registration (check brakes, lights, suspension, steering, ect...)
April - July: Drive to school, hot rod around in - ENJOY
August - December (2002): Garage again and begin prepping for paint / suspension work.
This is what i have planned (seriously...)
New Paint / Detailing
Vynil Seat Covers (I've gotta find a set for the Trans-AM seats)
Vynil Door Panels
3.42 Posi Unit
New Sway Bars
Polygraphite Bushing Kit
Boxed Trailing Arms / Panhard bar
TP
Bubbajones_ya
Jul 6, 2024 08:32 PM
86Firebird86
Dec 26, 2015 07:21 AM
plm99
Southern California Area
Nov 16, 2015 05:21 PM
92rsvortec350
Sep 10, 2015 10:54 AM
Wylecoyote08
Sep 8, 2015 08:26 AM
