Bad EGR?? Rough Idle
Car: 92’ Camaro RS Convertible
Engine: 305 TBI
My 305 is running rough at idle & acceleration.
Doesn't cut off, just runs rough.
I disconnected the bypass wire to set base timing, and it runs like normal.. once plugged back, runs rough again.
I did a smoke test for vacuum leaks and noticed smoke coming out of the EGR valve.
Is that normal? or is it leaking?
Can that cost the problem?
I’ve changed MAP sensor, IAC, TPS, & Spark Plugs.
Fuel pump & Filter are also new.
Car: 1992 Pontiac Firebird
Engine: 5.0L L03 TBI
Re: Bad EGR?? Rough Idle
My 305 is running rough at idle & acceleration. Doesn't cut off, just runs rough. I disconnected the bypass wire to set base timing, and it runs like normal.. once plugged back, runs rough again.
Yes
Disconnect the vacuum hose going to the nipple on the EGR valve, lift up on the vacuum diaphragm, put your finger over the vacuum nipple on the EGR valve to seal it off and let go of the vacuum diaphragm. If it holds vacuum it's good. If it doesn't hold vacuum and the vacuum diaphragm goes back to its normal position then it is bad and will need to be replaced.
You can also test the EGR vacuum diaphragm with a MITYVAC Hand Vacuum Pump or something like it.
