open ari element making noise. help!
Old Jan 27, 2002 | 09:30 AM
Nasty_Bird_'90's Avatar
hey guys. i just installed an open air element on my 90 bird and now it is making a hissing noise all the time. Yes, i plugged the unused vaccuum line. It sounds like it's coming directly from the throttle body. what is it and how can i stop it because it makes the car sound like s**t! thanx
Old Jan 27, 2002 | 11:15 AM
TBI305Camaro's Avatar
it does that you just have to live with it.
Old Jan 27, 2002 | 11:37 AM
Jza's Avatar
Jza
If the sound is coming from the IAC port, that sound comes with the installation. Stick your finger in there and see if the sound goes away (the car will bog for a second if you leave your finger in there too long). BTW that's the small, fingersized triangular port near the back of the TB; I don't advocate sticking your finger into places you aren't familiar with. If the still noise bothers you, you can always go with the HO dual snorkle setup and keep the silencer effect the factory setup offers.
Old Jan 27, 2002 | 12:05 PM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
I loved the noise
Old Jan 27, 2002 | 02:38 PM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
Yup they do that
Old Jan 27, 2002 | 04:53 PM
raycer's Avatar
Car: 86 IROC
Yep, like others have said, they sound like that, and I personally think it sounds sweet.
Old Jan 27, 2002 | 05:20 PM
vjo90RS8's Avatar
Car: 2002 Z28
i thought that was a bonus to the mod, i think it sounds cool
Old Jan 27, 2002 | 06:30 PM
i had done the same mod to my 88 camaro, same motor, no noise. maybe i'll have to live with it. thanx guys
Old Jan 27, 2002 | 07:21 PM
firbird's Avatar
well i do not think it is the iac, well atleast all the time,i am pretty sure when you are cruising around the iac sould not be open at all resulting in no noise comming from it, but on cold starts when your idle is at 1500 rpm that is the iac and it is letting air in and makes a lot of noise, more than likely what you are hearing when your driving inless you need to ajust somthing is your injectors
Old Jan 28, 2002 | 11:00 AM
i took the sealer (i dont know what its called it run along the back of the hood to keep sound and heat in and to keep rain from coming in) and it made it even louder but now the engines sound comes out and sounds sweet
theshackle
Sep 17, 2020 08:26 AM
Brinkkl2000
Aug 4, 2018 08:29 AM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
wruiz
Aug 13, 2015 09:07 PM
