Which edelbrock performer intake for my car?
Old Jan 31, 2002 | 09:48 AM
jm91rs's Avatar
do you have part numbers or something? Will I need to change anything else to put this on my car? What kind of differences will I notice? anyone know of a used one somewhere for cheaper?
Old Jan 31, 2002 | 11:30 AM
vjo90RS8's Avatar
Car: 2002 Z28
Edelbrock Performer TBI intake - part number EDL-3704 in summit i think. You can check ebay, every once in a while they have new or used intakes. New they are about 200 bucks.
Old Jan 31, 2002 | 11:40 AM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
I have the Edelbrock Performer TBI Intake Manifold.It's about 1/4" taller than stock,
but still clears the hood with 14x3" Flat Bottom Air Cleaner.Everything bolts up.I had to bend the
fuel lines a little to clear the intake behind the throttle body. Also, the boss is there for the A/C Compressor Support bracket, but it has to be drilled and tapped(in the front, near the thermostat housing).
Bought mine from Summit for $208.
-Rich-
Old Jan 31, 2002 | 06:48 PM
gcore45's Avatar
Car: '91 RS
Engine: 5.7 tbi
Hey Rich, how does yours run in the higher rpms?
Old Jan 31, 2002 | 07:46 PM
jm91rs's Avatar
what kind of differences have you noticed witth it.
Old Jan 31, 2002 | 08:54 PM
NJ SPEEDER's Avatar
you will notice that the will pull past 3500 rpm a bit better, if you add a full exhaust to the mix you will fell it pull to about 4500 before you run out of cam. do the ultimate tbi to really notice a difference.
later
tim
Old Feb 1, 2002 | 09:25 AM
Car: 92 Camaro RS
With a 350 and the Crane Compucam 2030,Ported Turbo City Throttle Body,SLP Headers , 3" Exhaust and Custom Chip,it pulls hard to almost 6000RPM.
-Rich-
86IROC112
Aug 17, 2015 02:00 PM
TreDeClaw
Aug 14, 2015 06:58 PM
89-S-dime
Aug 12, 2015 11:57 AM
mustangman65_79
Aug 8, 2015 12:07 PM
