Which aircleaner to get?
Old Feb 6, 2002 | 11:13 PM
Dan94GT's Avatar
I have a drop base 14x3 edelbrock on there now but I dont like the drop base and the spacer. It looks real restrictive to me. I can get a non drop base (just the base) for $17 and still use my nice edelbrock lid. or
For about the same price$2-5 more i could get one of those little triangular edelbrocks w/ the foam element. I think its called the pro flow. How well does this one work?
Old Feb 6, 2002 | 11:25 PM
firbird's Avatar
all i can say is dont put that pos proflow on top of your engine, and if you pretty much stock right now just a drop base is really good enough to were it would not make a difference
Old Feb 6, 2002 | 11:32 PM
NJ SPEEDER's Avatar
whatever cheapie 14x3 with a flat base your local auto parts/speed part shop has in stock. no need to spend big bucks on a big name.
later
tim
Old Feb 6, 2002 | 11:40 PM
GKK's Avatar
GKK
Car: 91 Camaro RS Update: Sold Camaro, now own a "91" Corvette.
Engine: Corvette L98 TPI
If you're thinking of getting that non-drop Base from Summit Racing for $17, the Edelbrock lid is about 3/4" too high and the tbi stud won't secure it. I have the Edelbrock drop base and also the $17 flat base from Summit and the only way the lid will fit is to turn it upside down. This is without the tbi spacer ring. The Edelbrock lid is just pointed too much. I think Moroso has a flat base that'll work.
Old Feb 7, 2002 | 10:43 AM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
I'm using the Moroso Flat Bottom Air Cleaner.
Part# 65911, $47.99 from Summit.
Fits under the hood with no modifications,
Chrome,14x3",no spacer required to clear throttle linkage.Might want to punch a hole in it for the air temp sensor.Or you can put it elsewhere.
-Rich-
Old Feb 7, 2002 | 09:40 PM
deadtrend1's Avatar
i thought taz or someone siad the triangular edelbrock rips apart after awhile? ANywho
K&N non drop 14'' x 2 1/4". Summit number "KNN-60-1263" $66.75
I just had to have the K&N logo after the drop base I had sat on my Coil plug wire boot, and sat unlevel. This is with the spacer ring i might add.
I used a little rubber plug laying in a misc. drawer in my tool box to plug up the line off the TB. I installed the IAT Sensor inside the Cleaner, but you can be lazy and let it sit. Or, use resistors which I have all the values written down from when Snufifigus (<---I tried) posted them.
~Tim
Old Feb 7, 2002 | 09:42 PM
deadtrend1's Avatar
i thought taz or someone said the triangular Edelbrock air cleaner rips apart after awhile? Anywho .....
I just had to have the K&N logo after the drop base I had sat on my coil plug wire boot, and was unlevel. This is with the spacer ring i might add, but its gone now and K&N gives you a rubber gasket that takes the place of the ring, and it looks and fuctions 100 times better.
I used a little rubber plug laying in a misc. drawer in my tool box to plug up the line off the TB unit. I installed the IAT Sensor inside the Cleaner, but you can be lazy and let it sit. Or, use resistors which I have all the values written down from when Snuflufigus (<---I tried) posted them.
~Tim
Old Feb 7, 2002 | 09:46 PM
deadtrend1's Avatar
I live the trick of getting a K&N stock element a chrome (or X-Stream) lib and using the stock base. That idea came along with the possibilty of cowl induction. Saw the setup on Speed Vision with "El Caminos" and "Rancheros".
~Tim
Old Feb 7, 2002 | 09:53 PM
deadtrend1's Avatar
~Tim
Old Feb 7, 2002 | 09:56 PM
deadtrend1's Avatar
HOLY S***, Someone delete those 3 outta 4 posts. I kept hitting "SUBMIT REPLY" and IE kept saying "Page cannot be displayed". Something on either end was lagging really bad. SORRY ALL MODERATORS! I tried deleting them myself but it gave me a access error. STUPID DIAL-UP EARTHLINK PIECE OF JUNK ISP!!!!!!!!
Old Feb 8, 2002 | 11:15 PM
TBI305Camaro's Avatar
i have a k&n lid on and a 14 inch non drop mr gasket bottom...clears everything perfect, 3 inch element and everything clears
MotorCityMuscle
Carburetors
Sep 23, 2001 11:07 PM
Dirtybird355
Carburetors
Aug 26, 2001 03:20 PM
86 sports coupe
Aug 7, 2001 09:58 PM
TAdan
Jun 14, 2001 09:51 PM
MuchoCamaros
Feb 4, 2001 12:40 AM
