Help a lazy guy w/oil leak?
Old Feb 9, 2002 | 10:58 PM
Joel Geerling's Avatar
Car: 91 Formula
Engine: 305 TBI
I'm not actually lazy, just time-starved, actually. There is oil spritzing up onto my distributor cap, the bottom of the back of my air cleaner base, onto back of throttle body, collects on back of intake manifold, it runs down onto the front of the tranny and back of oilpan, you get the idea. Not a huge leak, but I want to fix it.
Haven't had time to take a good look around - do you think it's the distributor's gasket? Is there anything else that could allow a leak to spray up in that area? Thx for advise!
Old Feb 10, 2002 | 12:14 AM
TBI305Camaro's Avatar
its either the valve cover gaskets, distributer gasket or the intake. mines doing the exact same thing so if you figure out for sure what it is post it. anyways i replaced my valve cover gaskets yesterday and i think it may have fixed it i havent been able to tell yet since i work 16 hours today and its to dark to check now. i felt around behind my intake i think thats whats leaking but im not for sure yet
Old Feb 10, 2002 | 09:22 PM
homebrew's Avatar
I had a mystery leak like that one time on my 350. It turned out to be coming from the block just behind the intake manifold. There is a hole there for if you have a mechanical oil pressure guage. If you have the electric one like most people do nowdays the hole I'm talking about usually has a little pipe fitting in it to stop it up. But on mine it was loose and oil was leaking from it. It was a real bitch finding it. If I were you I'd start the engine and look at everything really close while its running because if you just look after you drive it the wind blows the oil everywhere and you cant really see where it came from. Good luck.
Old Feb 10, 2002 | 09:26 PM
homebrew's Avatar
By the way Joel, hows that air cleaner working for you? I'm looking for one to fit on my 91 TBI camaro that will require no modifications in order to fit under the hood and fit around linkage and whatnot.
Old Feb 10, 2002 | 11:59 PM
Car: 91 Formula
Engine: 305 TBI
It works great and installation was simple. Besides having to drill out the embossed hole for the IAT sensor, the old stuff came out and the open element dropped in.
If you're still looking, you can find cheaper (ie $20 instead of $40) ones if you don't need it to say "Edelbrock" or "K&N" on top. And I've heard some discussion here re. not using a drop-base (sitting on the odd spacer ring that's on top of the throttle body, like the stock cleaner) open element because of better flow with a non-drop. Until I see some measurements, I'm not sure the difference is huge enough to make it worth an imperfect fit.
Infested
May 22, 2018 11:56 PM
87 camaro iroc
Aug 20, 2015 07:47 AM
formula_novice
Aug 18, 2015 08:48 PM
cstrobel65
Aug 15, 2015 10:19 AM
Street Lethal
Aug 14, 2015 08:25 PM
