smog pump removal
Old Feb 16, 2002 | 03:55 PM
wasp's Avatar
Car: 91 firebird,mint
Engine: 305 tbi,lots of work done
Transmission: 700-r4 built by level 10 in nj
Axle/Gears: 3.73, auburn , precision
smog pump removal
i have seen the tech article on the belt rerouting once pump is removed...is there a tech article on the actual removal procedure? im sure i could figure it out as i went along but i remember reading something on it somewhere just cant a memba where i do have all the stuff connected to it ripped out its just the pulley and pump left
Old Feb 16, 2002 | 06:05 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
just pull off the pump(youll hafta remove the pulley first) and plug the inlets on your exaust manifold/crimp the inlet on the catalitic converter. Pretty self explantiory IMHO. I took all teh crap off w/o much trouble. Just look at the tech article on teh belt routing and you should be in buisness.
Old Feb 16, 2002 | 07:26 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
you dont need to plug the exhaust manifolds, there is a one-way valve in there
Old Feb 16, 2002 | 07:38 PM
wasp's Avatar
well i dont need to plug any of that cuz i have headers with no air tubes and no cat but thanx
Old Feb 16, 2002 | 11:27 PM
ir0cz's Avatar
Car: '89 RS
Engine: 9C1 w/ TPI
Transmission: rebuilt 700R4
What size belt if you have AC? Cause I removed mine, and tried every size belt available, and could not find a fit. I ended up having to put the pump back on, but i gutted it out so that it had no resistance.
Old Feb 16, 2002 | 11:44 PM
1MEAN92RS's Avatar
Car: '92 Rally Sport
Engine: LO3
Belt size for AC with removal is a 98.6 inch 6 rib belt I believe. Just refer to the tech article.
Old Feb 17, 2002 | 12:13 AM
ir0cz's Avatar
Car: '89 RS
Engine: 9C1 w/ TPI
i tried whatever size the tech article said, but it didn't fit?
Old Feb 17, 2002 | 02:01 AM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
Are you routing it correctly, cause mine fit perfect.
Old Feb 17, 2002 | 06:31 AM
wasp's Avatar
know how i do it? i use a seemtress tape, follow the route the hose should go and get as close as possible......i try to get it a little longer cuz you do have the tensioner, but not too long
Old Feb 17, 2002 | 06:33 AM
wasp's Avatar
and i wouldnt go by the generic length thats being posted if youve changed to different pulleys like me..........i have a 1 1/8 pulley for my alt . the smallest pulley march makes.....and the standard underdrive size for crank from hypertech.........just a note
Old Feb 17, 2002 | 09:28 PM
ir0cz's Avatar
Car: '89 RS
Engine: 9C1 w/ TPI
Yea, ran it right. I know this because I put it on, and turned the car on and the belt ran like planned, it was just a little too loose...the accessories were spinning faster than the belt. The tensioner was as tight as possible...so i dunno? I have since switched to underdrive crank and alt. pulleys...what size would i need now if I wanted to take the smog pump off?
Old Feb 17, 2002 | 10:33 PM
i had to get a different size belt then the article said to get
Old Feb 18, 2002 | 09:05 AM
wasp's Avatar
you guys obviously arent reading my posts........take a seamstress tape measure,thats the flexible one they use to measure you for pants? have a friend hold it in place and run it the same route your belt would run..walla!! your belt length is revealed
Old Feb 18, 2002 | 09:12 PM
ir0cz's Avatar
Car: '89 RS
Engine: 9C1 w/ TPI
We get that man....my problem wasn't w/ ur post....it was w/ the parts store...they didn't MAKE the size belt i needed. I tried 2 or 3 different store. And none of them had the size i needed....so i tried the closest 2....they were just a bit too tight, and just a bit too small.
Old Feb 19, 2002 | 05:08 PM
wasp's Avatar
call summit
RazorN8
Jan 7, 2022 11:44 AM
italiano67
Dec 11, 2016 09:21 AM
backtothe80s
Sep 5, 2015 12:39 AM
3rdgenparts
Aug 8, 2015 07:09 PM
mustangman65_79
Aug 7, 2015 09:55 PM
