Oil Pressure question & check out my new wheels!
For some reason today, my oil pressure gauge read with the needle at maximum (about 70-80 on a 0-60psi gauge). It did not go down to 0 after the car was shut down, so I suspect the sender has failed. I'd just like some opinions on what else could be wrong
Don't ignore it! Watch that guage!
Might be your oil pump.... my gauge was going batty just before the oil pump went out, then the whole engine!
it would read really high... then zilch then really high
then tick tick tick tick tick tick (can we say rod?)
(The sound you don't want to hear)
i looked into all the stuff for that job. it's gonna be like $40 for parts and a whole bunch of time to take off the pan. all the parts came from pepboys, but the pan looks like it has a one piece rubber gasket that should be re-usable. plan for alot of time before you replace the pump. looks to be a bear.
pepboys? Oh ***... I just spent $350 on the front end work on my camaro to have brakes and an idlr arm put on including rotors and alignment... The alignment was done wrong ... bolts left loose.... Brakes adjusted to tight... . and the lugs just scrwed on.... they were supposed to check the back brakes... can we say.... What back brakes? They didnt even look!!!! I took my car back 3 times now and they cant get the Fuggin things right!. I will never buy nor recommed pepboys for anything... NOT EVEN PARTS!!!!!
Sorry.... That was My opinion.......
Car: 91 firebird,mint
Engine: 305 tbi,lots of work done
Transmission: 700-r4 built by level 10 in nj
Axle/Gears: 3.73, auburn , precision
i have 91 tbi bird..try wiggling your ignition switch....mine reads scrwey sometims and if i wiggle the switch it starts to read again.........im guessing the ingnition switch is on the way out
Car: 1992 Camaro RS
Engine: 355
Transmission: th400
Axle/Gears: 3.89
if you need the sender i haev one new in the box email me if youre interested
camaroracer1992@yahoo.com
91/92's
Turn signals are below the fascia.... So are fogs...
Only oin the 91/92 models.
http://www.lvfbody.com/whoismember_p...p?MemberID=101
You can see them better here.
Thanks for all the replies.
The shaker scoop is part of the Bandit II scheme. It is fake, just bolted onto the hood. I have a real one to go on it, whenever I get time.
It started to read normally today, then jumped back up to maximum. I'll try your suggestions, and with 140k miles it may be a good idea to get that pump checked
. If my sender is dieing, I'll give you an email. Just need some time to check things out.
My car is not a formula, but I have all the WS6 stuff save the springs, and steering column. This is what the car looked like before
. If my sender is dieing, I'll give you an email. Just need some time to check things out.My car is not a formula, but I have all the WS6 stuff save the springs, and steering column. This is what the car looked like before
Car: 2002 TT Corvette
Engine: 5.7L
2 things, replace the oil pressure sender switch right by the filter and see if that fixes it. second, do not reuse the gasket. gaskets are meant to only be used once... take my word on that one.
Car: 92 Camaro RS
Engine: 305 TBI
Hook up a real gauge to it and check the pressure before you do anything else, oil pumps seldom go bad, my gauge has been reading normal at idle and at anything over 1800 RPM it starts bouncing wildly and then pegs the gauge out, it's been doing this for 4 years and no problems yet. I did check it with a real gauge when it first started acting weird and it had normal pressure.
That sounds like a great idea, hooking up a live gauge to car, I was not aware it could be accomplished, but I am learning all the time
. I had planned on replacing the gasket anyhow, no disrespect to you Jason Bennett, but I have yet to have had a good experience re-using old gaskets, and I cannot go wrong with a new one, if the case presents itself where I would need one.
Thanks for all of the replies, I now have a very solid base for tackling this problem.
Clint
. I had planned on replacing the gasket anyhow, no disrespect to you Jason Bennett, but I have yet to have had a good experience re-using old gaskets, and I cannot go wrong with a new one, if the case presents itself where I would need one. Thanks for all of the replies, I now have a very solid base for tackling this problem.
Clint
Navy8125
Aug 21, 2015 09:32 AM
