question about junk yard finds.....
Old Feb 27, 2002 | 12:03 PM
NXS055's Avatar
ok. I found a place close to my house and they have about 5 or 6 thirdgen camaros. most of them are the older sc's but thats cool. I found a rear end out of a camaro that came stock with a 2.8 v6 manual. it should be a 3.42 right? it'll be an open rear end but from what I understand you can purchase a take off gear from SLP that will make it possitive.... he wants 125 dollars for the whole rear end assembly.... good deal or not????
also, i found springs off of a 91 Z28.... just the front ones though (the back of the car burnt). would it be ok to put these on the front of my RS (came with F41 suspension package) but leave the stock springs on the rear... good idea or bad???
he wants 20 bucks for the pair... i think thats a fair price???
thanks
Old Feb 27, 2002 | 12:13 PM
Tas's Avatar
Tas
$125 seems a tad high. Ask the v6 board guys what gears that should have. Hard to say about the springs. Do they look beefier than yours? Doing front springs is a big job it might not be worth it unless you put in some quality springs and/or struts.
Old Feb 27, 2002 | 01:57 PM
NXS055's Avatar
well unless the car is an 82 model then the standard rear gears for a 6 cyl. manual is 3.42 if its an 82 then it'll be 3.23... either way that'll be a nice change from my 2.73's.... you think 125 seems high??? i could probably talk him down some... i thought that sounded pretty good....
also, won't the z28 springs be a big change over the f41 that came on the RS...??? thats what i've always thought... i could be wrong however, i've been wrong before... not often though
Old Feb 27, 2002 | 02:02 PM
Tas's Avatar
Tas
pablo got his v6 rear for $50. I haven't priced them in my area yet but after I get my stuff(headers, exaust, intake) on, v6 rear + SLP posi, and aluminm driveshaft will probably my next mods.
Old Feb 27, 2002 | 05:08 PM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
I bought a 3.23 Posi disc rear at a garage sale for $50.The guy actually apologised for selling the sway bar off it earlier.
I see disc brake posi thirdgen rears in Northern CA for less than $150 frequently.
-Rich-
Old Feb 27, 2002 | 05:11 PM
NJ SPEEDER's Avatar
the best places to go are U-Pull-It's. you can usually get a complete rear from drum to drum for under $50. my local place say "Third member, minus drums/disks $36" since the drum arte only $5 each, you can see what i am saying
get dirty and save money
later
tim
Old Feb 27, 2002 | 07:22 PM
Tallboy's Avatar
is there an axel code listing for 3.42's?
i can use a fourth gen rear too?
r all those 3.42?
Old Feb 27, 2002 | 07:29 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
fourth gen Zs with a 6 speed have 3.42s. the autos have either 3.23 or 2.73
Old Feb 28, 2002 | 07:49 PM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
I was goin to use the same posi from slp but come to find out they use 28 spline axles and your rear has 26 spline so thats out the window. Hope that helps.
Old Feb 28, 2002 | 08:07 PM
NXS055's Avatar
so the rear from the v6 won't work????
oh man.... that sucks butt crack.... hahahaha
now i gotta try to find one.... ewe, thats too much like work
hahahahah
thanks
Old Feb 28, 2002 | 09:11 PM
steve8586iroc's Avatar
All you need to make any axle work ( thirdgen that is ) is to get some 28 spline axles from the same salvage yard. If it originally had 26's and you want to use the slp take off posi all you need is the 28's. Now your ready to RUMBLE.
Old Feb 28, 2002 | 10:28 PM
NJ SPEEDER's Avatar
our cars all have 28 spline axles. there is no need to do any other shopping, you already have the axles you need. all the bearing and teh housings stayed the same, just the spline count on the end of the axle changed.
later
tim
Old Feb 28, 2002 | 11:21 PM
My305camaro's Avatar
All the yards around my neck of the woods want $250-$300 for a complete rear. True they are not U-pull-ums but I can't find a good one that has Camaros. Oh well...
Old Mar 1, 2002 | 09:05 PM
NJ, are you saying that the 88 and later are 28 spline axles?
Steve
Old Mar 1, 2002 | 09:29 PM
i think he is
Old Mar 1, 2002 | 09:47 PM
The only reason to get extra axles is to have a complete rearend ready to swap out, less down time if on a tight schedule.
Old Mar 1, 2002 | 10:03 PM
Tallboy's Avatar
88+ rear r 28 spline?
r all v6 4th gen axels 3.42???
sumwhere theres gotta be a listing of axel codes/casting numbers
did all 4th gen Z's formula-t/a's come with an aluminum dshaft???
:lala:
Old Mar 1, 2002 | 11:38 PM
NJ SPEEDER's Avatar
88 and up is 28spline axles.
not all V6's are 3.42 gears. most thirdgens are, but not all. in the 4th gens it is much more common to find 3.23 gears in a V6 that to see 3.42's. 4th gen rears are also wider than thirdgen rears, so your wheels will stick out further.
just go to the salvage yard and look at teh RPO(the little 3 digit option codes), you are looking for one that says GU6. in camaro's teh codes are in the console box and on birds the codes are on teh lock box door in teh hatch.
later
tim
Old Mar 3, 2002 | 09:47 AM
Tallboy's Avatar
i just read that all 5sp v6 have 3.42 rears... is this true?
i found a 4th gen rear mated to a 5sp 6 cyl with disc brakes
i have heard t hat u have to change the brake lines if there is a reluctor on it, WHAT DOES A RECLUCTOR LOOK LIKE, what does it do????
thanx
Old Mar 3, 2002 | 03:28 PM
NJ SPEEDER's Avatar
thanx
not every anything got a 3.42 gear, it coudl be a 3.42 or a 3.23, you have to look at the RPO code or count the teeth on teh gears to tell. gm was never real specific about what gears went where unless a car was ordered a specific way.
we do not have a reluctor ring on our cars, the reluctor is used on teh 4th gen vehicles equiped with anit lock brakes, it will not apply to our cars.
later
tim
Old Mar 3, 2002 | 03:46 PM
DM91RS's Avatar
Car: 91 RS
Guys be checking the axle splines because on the '89 RS that I had even the Auburn book said that it was the newer splined shaft but after buying a posi and getting it apart it was not.
I think that GM just used up what they had of the older axles and when they ran out thats when you would get a newer style.
Old Mar 4, 2002 | 12:48 PM
NXS055's Avatar
ok so now back to me....
if i go to the junk yard and purchase the entire rear assembly, axles, gears, carrier.... the whole deal... would the slp gear work or not??? i'm confused.... and is there any other option to make it posi if that won't work???
i need to buy the thing anyway cuz its a 3 series carrier and I have a 2 series (2.73) so even if I choose to buy a 3.73 posi setup i'll still need the carrier right???
ok... i'll just leave it at that for this post...
but i have more questions... hahaha
thanks....
:lala:
Old Mar 4, 2002 | 04:51 PM
NJ SPEEDER's Avatar
that sounds really odd. according to gm the change over was actually made at teh end of teh 1986 model year, which left some 87's with the 26's and some with 28's. you are right about the just using up what ever thing though, i have seen people with cars built as late in the run as april of 87 with 26spline axles.
just one more example of gm being nto too picky about soem parts
later
tim
TheJoeY88
Dec 31, 2016 07:30 PM
oscarfromla
Southern California Area
Sep 1, 2015 12:39 PM
thefirebirdm@n
Aug 25, 2015 05:21 PM
bbernardo94
Aug 19, 2015 05:25 AM
redmaroz
Aug 16, 2015 11:40 PM
