Holley TBI Adapter... What TBI unit has same size bores?
Old Mar 1, 2002 | 06:45 AM
91Firecrow305TBI's Avatar
I have one of these and a Holley Dominator Intake Manifold coming for my car early next week, and I wanted to know what size throttle body fits on this spacer? Would a L05 tbi work? or would I have to get a 454SS or Holley TBI unit? Is it possible to just bore out my L03 TBI to match.
Thanks for the replies, if any
Clint
Old Mar 1, 2002 | 04:25 PM
PaulD's Avatar
Car: 93 9C1 Caprice
Engine: 5.7
Axle/Gears: 3:42
Not sure I understand what you are trying to do but. small block TBIs have 1 11/16" bores (including l05) and big blocks and the Holley have 2" bores. The bolt pattern is the same. And, yes, it is possible to bore the stock manifold but since you're getting the Dominator, I'm not sure why you're asking. Hope this is some useful info.
Old Mar 1, 2002 | 09:06 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
Re: Holley TBI Adapter... What TBI unit has same size bores?
IMO it would be easier to buy a bigger throttle body, if you needed it. what is your setup?
Old Mar 4, 2002 | 06:45 AM
Still running stock heads, plan on going with Vortec heads/performer RPM intake later
V
Old Mar 6, 2002 | 07:46 AM
TP355Z's Avatar
Car: 1988 Camaro SC
Engine: LT1 SBC
Transmission: LT1 T56
Axle/Gears: 3.73 Moser 12 Bolt
If you're running the stock motor (basically) then use the stock TBI unit with the Holley intake. The bores on the intake will just be bigger (2 inches as opposed to 1 11/16 inches)
TP
Old Mar 6, 2002 | 11:23 AM
That is pretty much what I wanted to know, whether or not it was time to move forward with a larger unit or not. I will definately do that when I get the vortec heads and RPM Air-Gap intake.
Clint
Old Mar 13, 2002 | 06:26 PM
steve8586iroc's Avatar
Hey firecrow what kind of hood do you have or should I say scoop? Looks like a Trans Am shaker or it it just a stock Formula hood ?
Steve
Old Mar 14, 2002 | 06:33 AM
That hood has a fake shaker scoop bolted onto it. It was part of the Bandit II package, that had all of the pinstriping, hoodbird, etc. Right now I have a 86' Trans Am hood on it with a Harwood 2 1/4" cowl scoop to feed my car fresh air.
For more information on Bandit II, here is a site I made for it.
http://Bandit2ProAmRegistry.homestead.com/main.html
Old Mar 14, 2002 | 08:22 PM
I was hoping you might have used a real shaker scoop. Oh well I'll just have to make my own.
Steve
Old Mar 15, 2002 | 06:45 AM
I do have one from a 80 or 81 4.9 T/A. I did not use it because it would be too hard to get it to work. I know there are places that will make them custom to your car. I know someone who knows places. Let me talk to him, and I'll try and pass on the info.
Clint
Old Mar 15, 2002 | 08:25 PM
Due to the intake I'll be running I'll probably have to make my own anyway. It's an RPM Air Gap with at least an 1" spacer/adapter.
Steve
Old Mar 18, 2002 | 06:22 AM
Yea, that is the reason I went with a cowl, I have the Holley street dominator 300-36 intake, and the tbi adapter plate, It's very tall.
MustangBeater20
Oct 29, 2022 09:20 PM
toronto formula
Nov 10, 2015 06:17 AM
NinjaNife
Aug 23, 2015 11:49 AM
89-S-dime
Aug 12, 2015 11:57 AM
knight72
Aug 10, 2015 09:32 PM
