Fuel Pressure gauge
Old Mar 2, 2002 | 09:42 PM
92RS shearn's Avatar
Car: 92' RS
Engine: LO3
Transmission: Probuilt 700R4
Axle/Gears: 3.70 9-bolt
Fuel Pressure gauge
I am going to turn my FPR into an AFPR when I get my car back in a few weeks. I was wondering if anyone has managed to mount a gauge somewhere that it may be viewed at any time. Since I'm pretty sure it would have to be mounted after the regulator.
Old Mar 2, 2002 | 10:32 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
from what i have seen you can just mount it in-line. you can get an electric one and mount it in your car, or mount it just in the engine compartment, or if you have a cowl-induction hood you can mount it somehow so its in the cowl.
Old Mar 3, 2002 | 07:29 AM
DM91RS's Avatar
Car: 91 RS
Re: Fuel Pressure gauge
You mount it in the larger fuel line coming to the engine. Sorry about the photo quality. It has an under the hood Summit quage (with oil turned brown) and an in the car guage to monitor while driving.
Old Mar 3, 2002 | 07:34 AM
DM91RS's Avatar
Car: 91 RS
The inside guage can be mounted where you can see it ez.
Old Mar 3, 2002 | 07:51 AM
JokerRS's Avatar
Car: 92RS
Engine: 357
How's that bad boy running with those mods? Any time slips or g-tec? Did you have the vortecs milled?
Old Mar 3, 2002 | 08:33 AM
DM91RS's Avatar
Car: 91 RS
No time slips and haven't hooked up the g-tec lately. It runs strong but I'm still tuning the prom for better results then I'll try for some times.
I have had it up to 130 and still pulling
No I did not have the heads milled and don't think that it's necessary.
Old Mar 3, 2002 | 01:29 PM
mattRS's Avatar
how did you get past the speed limiter? just use the tech article or what?
Old Mar 3, 2002 | 03:59 PM
DM91RS's Avatar
Car: 91 RS
LOL
The speed limiter has a setting in TunerCat called "fuel cut off speed". I set it at a speed that will never be attained.
That was the first 305 chip mod that I did
Old Mar 3, 2002 | 05:54 PM
Car: 92' RS
Engine: LO3
But won't the fuel pressure before the regulator and the pressure after the regulator be different?
Old Mar 3, 2002 | 06:31 PM
PaulD's Avatar
Car: 93 9C1 Caprice
Engine: 5.7
Axle/Gears: 3:42
sure it will. You can tap into the line from the pump anywhere before the regulator. The regulator controls the pressure of the supply line, like a pressure relief valve. Everything upstream of the regulator is pressurized, everything downstream is not.
Of course, the inside mounted fuel pressure gage uses an isolator so fuel line is not coming into the passenger compartment. Autometer makes such a unit in the Summit catalog.
Old Mar 5, 2002 | 12:25 AM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
there is mine. if you dont have the stainless fuel lines, you can just put an inline in the same spot using some rubber lines. or you can tap into the ~12" rubber line near the "frame rail".
obviously, you cant see it at "all times", but you can see it with the hood open.
-brian
Infested
May 22, 2018 11:56 PM
86IROC112
Aug 17, 2015 02:00 PM
R3500
Aug 17, 2015 12:16 PM
ChevyZ71
Aug 13, 2015 07:30 AM
Kaweh
Aug 9, 2015 02:54 PM
