need info on 193 heads
Old Mar 12, 2002 | 08:37 PM
pseudosport81's Avatar
I have a set of heads off a 1988 chevy 1/2 ton. The casting number is 14102193. Do these heads flow alright? What is the cc size? I'm looking for a set of heads to rebuild and port in class. If they are junk i'm not going to waste my time. I'm planning to use them on a TBI 327.
Old Mar 13, 2002 | 09:01 AM
boogie's Avatar
I would not use the heads you have listed. They have 76cc combustion chambers and a really restrictive intake port.
Lonnie
Old Mar 13, 2002 | 01:27 PM
91_hd's Avatar
I have those listed as 65cc swirl port
Old Mar 13, 2002 | 03:15 PM
boogie's Avatar
The heads were used primarily on 87-95 TBI 350 trks and do have 76cc combustion chambers with would lower the compression ratio on a 327 with a flat top piston to about 8.0:1.
The heads are called swirl torque but have a swirl vane in the intake runners that restrict flow, however they do make respectable low end torque.
Lonnie
Old Mar 13, 2002 | 03:59 PM
PaulD's Avatar
Car: 93 9C1 Caprice
Engine: 5.7
Axle/Gears: 3:42
They also came on 350 TBI Caprice police cars. They are 76cc with small valves. If they are free, they would probably be suitable for a small displacement engine like the 327. You'll need to compensate for the larger cc combustion chamber or your compression will be down.
Old Mar 13, 2002 | 05:11 PM
Yes the heads are free. I used the 88 350 in my 69 camaro with trick flow heads. I havent bought the pistons yet. I was going to wait until i figured out what heads i'm going to use. The only other set of heads I have are off an 88 cop car that came with a carb but i havent looked at the casting numbers yet.
Cornholio7979
Sep 20, 2018 02:31 AM
509 camaro fan
Sep 6, 2015 10:43 AM
ambainb
Aug 29, 2015 12:43 AM
anesthes
Aug 8, 2015 09:37 PM
