305 HO Heads on my LO3
Old Mar 13, 2002 | 05:57 PM
un4givin89's Avatar
These should bolt right on and I already know they are alot better than the LO3 heads, duh.
With my exhaust and cold air intake, and these heads, do you think I can get past the 200hp wall or at least be at the wall?
What should I except when installing these? Will my current intake match up?
Old Mar 13, 2002 | 06:16 PM
DM91RS's Avatar
Car: 91 RS
Are these the L69 heads which end with a casting number of 416? They are supposed to be one of the "better stock" 305 heads. What intake do you want to use and what are your other mods?
Old Mar 13, 2002 | 07:08 PM
un4givin89's Avatar
What I know is the block is an 305 TPI with factory HO heads. Its free so I'm taking it.
I've currently just got an exhaust and the usualy TBI mods. And I wanted to use my stock mainafold from my LO3
Old Mar 13, 2002 | 07:19 PM
DM91RS's Avatar
Car: 91 RS
Are they centerbolt heads? If they are they should be casting number ending with 081 I think and they should work well with your stock intake.
This would be a good time to learn to port heads if you have the equipment needed or can borrow.
I am getting a set of those from my son-in-law and will be porting and replacing springs and seals to go on my 305. The Vortec's I'm running will be used on a 350 build up.
Old Mar 13, 2002 | 08:45 PM
un4givin89's Avatar
I'll have to check it out tomorrow when I go to pick up the heads.
Old Mar 14, 2002 | 12:26 AM
RSRagtop's Avatar
Centerbolt heads drop right in, Perimeter bolt head require re-angling the 4 center bolt holes in the intake. Either way the best place for the TBI swirl heads is the trash can.
Old Mar 14, 2002 | 12:50 AM
HrdRockA4305's Avatar
un4givin man you beat me to it!
I had a couple Ideas about heads. One was yank the heads of my freinds 305 he pulled out of his 85 HO Trans AM (which was replaced by a vortech 355. Woohoo!) The only concern I had was accessories bolting up and a TBI intake fitting it.
The other was if/when i can get the bucks together to rebuild the motor, put some centerbolt 305 HO heads on. 3rdGenResource sells them for like $100 a pair, and they've gotta be better than the L03 Swirl port heads. You guys think a rebuilt 305 with the HO heads, an LT1 cam, and an edelbrock TBI intake would be a nice low budget engine? I mean I'd be happy with like 230-250 HP
honestly.
"Either way the best place for the TBI swirl heads is the trash can"
I'd like to use mine as parking blocks personally. (the garage is a tight fit, seriously by GFX are six inches from the freaking lawn mower right now and thats too close a distance to risk guessing about). It'd be cooler than the bricks I'm using right now! Gotta replace them with something first though!
Old Mar 18, 2002 | 02:23 PM
NTChrist's Avatar
Are you sure that that price is for a PAIR of heads? It sort of looks like they're trying to sell you a single head for $100.
What was the consensus? 305 TPI heads worth the effort? Thanks lots.
Old Mar 20, 2002 | 06:39 PM
NTChrist's Avatar
btt
Old Mar 20, 2002 | 08:28 PM
iroc22's Avatar
Hey check out my other post "Super head comparison"...its down a bit. It has a lot of good pics of these heads and the worlds. Check it out.
Old Mar 21, 2002 | 11:23 PM
"Are you sure that that price is for a PAIR of heads? It sort of looks like they're trying to sell you a single head for $100. "
Yeah you're probably right. I don't always pay much attention to little details like that. Bad habit.
Jake_92RS
Jan 28, 2020 10:37 PM
gta90
Sep 15, 2015 04:00 PM
theurge
Aug 21, 2015 12:46 PM
