Car to hot
Old Mar 13, 2002 | 07:16 PM
bandit45's Avatar
Car to hot
What are some ways to keep my car cold, cause good *** is it slow when it gets hot. Once I shoot my bottle I'm at 220 and after that its horrible.
Old Mar 13, 2002 | 07:28 PM
firbird's Avatar
try a lower fan switch, lower tstat, and make sure the mixture is right and if you are still having problems somethings not right. i run my vortec 350 on the stock rad, and have a fan switch and a 180 t-stat and runs at 184 and raises like 2 deg when i push it
Old Mar 13, 2002 | 09:36 PM
Gunny Highway's Avatar
Car: 91 RS
Engine: 350 TBI
Like he said, go to a lower temp thermostat. The stock one is 195* I believe, I went to a 180* and it works very well. Just make sure you get one made out of brass. It cost like $6 or so, but it's accurate within 5 degrees.
Secondly, go get yourself some Water Wetter. It's made by Redline and you should be able to pick it up at any Pep Boys. I can't really explain the chemistry of how it works, it just does. Ask around, it has a very good reputation.
Lastly, if cold weather isn't an issue where you live, you might want to think about switching to a different mixture ratio in your coolant system. Water has a higher boiling point than anti-freeze, so the risk of overheating is decreased. Go to something like 60/40 or 70/30 mixture in favor of water.
Old Mar 14, 2002 | 08:52 AM
TBI305Camaro's Avatar
my car used to run at 220 all the time...well my fan switch broke so i overheated once and have to rig a fan switch for the time...since then i had to replace the radiator, thermostat, and water pump...with the 180 degree stat i never get over 160 here and thats without the fan..i had a 160 in there and it rarely made it off 100 degrees...seemed like it messed with the car bad tho and got horrible gas milage
Old Mar 14, 2002 | 03:57 PM
Car: 91 RS
Engine: 350 TBI
If you go too cold, like 160*, yes you will get better performance, but it's minute compared to the hit you'll take in economy.
Old Mar 14, 2002 | 07:45 PM
firbird's Avatar
305tbi I don’t think you were running at 100 deg with a 160, your gauge is prolly messed up if you put in a 160 t stat in it will either be 160 give or take 5 deg and up temps your engine is going to run at. With a 180 t stat it could be below zero out side and I could spray the radiator with water but it will not go below 175 because it will close back up and not let any water from the radiator in the engine.
Old Mar 15, 2002 | 08:37 PM
TP355Z's Avatar
Car: 1988 Camaro SC
Engine: LT1 SBC
Transmission: LT1 T56
Axle/Gears: 3.73 Moser 12 Bolt
Just a note guys - i went through 2 new fan temp switch sensors w/my formerly 305 TBI Camaro and the stock setting turns the fan on around 236*ish (c'mon - tell me i'm wrong) because I had ACME Auto and a Car Quest shop confirm that temp for the proper sensor for the car. I spent the $15 and got a sensor that kicks the fan on at 220ish, the low-temp thermostat is next.
TP
Old Mar 16, 2002 | 10:02 AM
dilligaf's Avatar
TP
You're right. No one belived me either.
I changed the thermostat and then set the fan up to run whenever the engine does (summer only).
Works Great.
Old Mar 19, 2002 | 12:03 AM
Doneggo's Avatar
buy a 3 core radiator from radiators.com. they are worth it and help keep the temp. down.
Old Mar 19, 2002 | 02:35 PM
BPA's Avatar
BPA
Check your timing, if it is to advanced it will cause premature burn and create exsesive heat.
theshackle
Mar 5, 2017 06:37 PM
TheExaminer
Aug 26, 2015 04:59 PM
mustangman65_79
Aug 11, 2015 03:17 PM
86Base
Aug 8, 2015 01:34 PM
