Running Lean.... any ideas
Old Mar 14, 2002 | 12:43 PM
NXS055's Avatar
My car is running lean, to the point that it killed my cat and you can smell raw gas out the exhaust... this is bad and needs to be fixed... i'm putting on new plugs and wires this weekend... if this doesn't work, what would you suggest... keep it reasonable too, i'm on a budget, a tight one...
thanks
Old Mar 14, 2002 | 12:50 PM
Fish89's Avatar
Car: 89 Camaro
Engine: 97 LT1
Axle/Gears: 323 Posi
Possible O2 sensor
Old Mar 15, 2002 | 12:35 AM
TZFBird's Avatar
Car: 1988 Firebird, 2000 GTP
Engine: 327
Axle/Gears: 9" posi, 4.11
I'm not sure, but have you checked the Fuel Pressure Regulator? If that goes bad, I think it will run lean. Maybe have a look at the fuel filter.
unless I forgot, but I always thought the O2 sensor would make you run rich. because your mileage gets bad when the O2 sensor is getting bad.
Old Mar 15, 2002 | 11:50 AM
91Bird305's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
CTS Sensor will do that too. Its the sensor in front of the thermostat. Check the voltage to that and see if thats working correctly.
camaro11j
Sep 19, 2018 08:49 AM
pimp2303
Jul 27, 2017 02:03 PM
Fast355
Dec 2, 2016 06:33 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
