Cold Air Induction or Open Element?
Old Mar 18, 2002 | 11:21 PM
The_Prostitute's Avatar
I have a 1992 Chevy Camaro RS with TBI; I just bought it and its pretty much stock. The question is should I replace the factory air induction system with a cold air induction system or an aftermarket open element setup. I know both would be better than the stock setup but which is best? I don’t want to spend a lot of money so buying a $200 plus aftermarket cold air induction system is out of the question. I was thinking either finding a used H.O. snorkel air cleaner or buying a good aftermarket open element air cleaner. Can someone please give me some suggestions as to which method you would use?
Also I live in Florida, I am at about sea level and I changed my cooling setup so the car runs at 180 degrees instead of stock. Don’t know if that means anything but I figured I should let you know.
Old Mar 18, 2002 | 11:32 PM
vic_V8's Avatar
Car: RS
Transmission: 4L60
https://www.thirdgen.org/techbb2/sho...t=open+element
this was the topic of the week last week, but you are new
the fastest way to find something is by doing a search, and if it isn't there then post your specific question,
I'm glad someone told me that when I was new,
Old Mar 19, 2002 | 10:16 AM
Thanks, their is a lot of good information their. However it still did not anwser my question. !Which is better cold air induction or open element? I cant decide which to use open air or cold air. Please give me some suggestions.
Old Mar 19, 2002 | 10:47 AM
TBI305Camaro's Avatar
he told you were to go to get all the info on that youll ever need
Old Mar 19, 2002 | 10:56 AM
I read every article and they never stated which was better, cold air or open element!
Old Mar 19, 2002 | 11:05 AM
the colder the air the better but the open element works wonders over the stock crap...im running a 14x3 non drop base k&n open element...works great and looks much better...clears up the engine compartment some...so does ripping out the emmissions, AC, air injection but i wouldnt know about that
Old Mar 19, 2002 | 11:36 AM
vic_V8's Avatar
Car: RS
Transmission: 4L60
my vote is for the open element, sounds cool (you'll find out), looks cool, and is dirt cheap compared to the cold air stuff, mine was 32 bucks (Mr. Gasket) now I have a extra one and I'm gonna paint it red and have a buddy air brush something on it
Old Mar 19, 2002 | 11:45 AM
Thats the type of anwsers I was looking for, thanks and please keep them coming.
Old Mar 19, 2002 | 12:04 PM
Lurch's Avatar
Check this out. http://91rsramair.tripod.com/
It may not be the nicest looking but it is probable the best homemade system I've seen. I'll be trying this my self soon. It will cost under $100 to make $50 of that being for the 2 K&N Filters($25.99 each) . I guess it will take 2 to 3 hours and give 10 to 20 hp.
Also check this out it will better show how the tubes route in the front end. https://www.thirdgen.org/newdesign/tech/ramair.shtml
This set up will provide all the cool air the LO3 will ever need plus an added ram air efect at speed.
Hope this helps.
Old Mar 19, 2002 | 02:39 PM
vic_V8's Avatar
Car: RS
Transmission: 4L60
lurch, your first site didn't work for me
Old Mar 20, 2002 | 06:10 PM
Lurch's Avatar
The server for the site has been going down off and on some times it works some times it don't. Good luch the last time I tried it did.
Old Mar 21, 2002 | 01:14 AM
Any other suggestions?
Old Mar 21, 2002 | 09:05 AM
pimpintheRS's Avatar
cold air induction in florida???it is hot over there like it is over here almost... just go with a open element from edelbrock you can pick them up at autozone checkers,kragen what ever you have on the east coast...almost 90% of the guys using tbi use open element only a hand full try the cold air induction...
my vote is to open element.. with the chrome top it looks sweet cleans your engine bay up:lala: i love the dancing marshmellow man...:lala:
Shawn
Old Mar 21, 2002 | 05:39 PM
Tallboy's Avatar
forgot the link
but thier is another idea using sheet metal on formula hood
and sealing the aircleaner to it(pulling out bulge plate)
i was planning on doing that but now im planning on using a 2nd gen T/A aIr cleaner in conjunctioin with a flat hood
i hope itll work
cuz ILL never hear "I GOT ONE TOOO"
i have it at h ome but i m not home,stay tuned
ill try and post the link soon
Old Mar 21, 2002 | 05:55 PM
KZad's Avatar
Car: 88 Formula, 04 CTS-V, 06 Commander
Engine: 305 TBI, LS6, 4.7 V-8
Transmission: 5 spd, B&M Short Throw
I've had it both ways ... now I run the Open Element only.
My cold air was more of a 'ram air'. I had a 8 X 4 Funnel tucked up by the front air dam, which ran to 5' of 3inch metal dryer tubing that ran up through my quarter panel. (right where the battery would sit if it was on the driver's side.) Then connected to the stock air cleaner base. I did have to move a few things (like the horn and various other little stuff) in order to run the tube through the quarter panel.
The problem with that setup was that it was still pulling air through the 1 X 3 inch stock air cleaner base. Which obviously isnt enough.
I am very happy with the open air, especially with my formula hood which has the bulge plate removed (i found a honeycomb plate from a 82-84 TA and put that in there. Looks great)
The main thing that people say about the open air is that it DOES let the engine suck more air, however it sucks the HOT AIR from the engine compartment. Easy solution is a Cowl hood, or something like mine or what Tallboy is talking about...
Hope it helps ...
I say go with Open Element.
I got pics of mine if you wanna see.
KZad
Old Mar 21, 2002 | 06:27 PM
Ride4ME's Avatar
How do you remove the ac and the rest
of that crap of the stock air cleaner??
Old Mar 21, 2002 | 09:02 PM
vette9190's Avatar
Car: 1991 Chevy Camaro RS
Transmission: 700R4,
Axle/Gears: 3.73 w/SLP Zexel Torsen Limited Sli
coldddd air
Lurch
Thanks for the link I will Be trying this *** some as I can get all the parts. It looks like a sweete setup.
Brinkkl2000
Aug 4, 2018 08:29 AM
stalkier
Dec 6, 2015 11:25 PM
kyle5647
Aug 15, 2015 11:56 PM
wruiz
Aug 13, 2015 09:07 PM
