were is the IAC and how do you clean it on a v-8 camaro
Old 03-20-2002, 12:23 PM
89 red RS's Avatar
were is the IAC and how do i clean it on a v-8 camaro
plus i found the tech article on how to adjust your tv cable on a v-6 but does anyone have a pick or aticle on how to do it on a v-8 89 camaro rs
i've always been a carberator guy not used to tbi so excuse my ignorance thank you!!!
Old 03-20-2002, 02:37 PM
firbird's Avatar
you can use a little carb cleaner and spray it down there and it will clean it out. i have a pic of my holley unit and its similar to the stock on but you just spray the carb cleaner down the port.
ajusting the tv cable sould be the same if not VERY similar to the v8 i would think
Attached Thumbnails were is the IAC and how do you clean it on a v-8 camaro-tbi-2.jpg
Old 03-20-2002, 02:39 PM
firbird's Avatar
well if it is fully warmed up it sould be closed and it really will not get anywere, i guess you can wait till cold start up when it uses the iac and it is open.
Old 03-20-2002, 02:59 PM
89 red RS's Avatar
thank you
would this help me get the car to idle better?
plus the reason i can't seem to adjust the tv cable on mine is becuase the pic in the tech article doesn't seem to clear to me.
thanks
Old 03-20-2002, 10:13 PM
firbird's Avatar
it might, but more then likley not if it is not leaking when fully warmed up. you might want to check the basic stuff first like igition ( cap, plugs, wires) and fuel filter, timing, tps.
Old 03-20-2002, 10:24 PM
JPrevost's Avatar
Car: 91 Red Sled
If you want to get the IAC to come all the way out use a paper clip and put the car into ALDL mode. All you need to do is put the key in the on position and the IAC will close (stick out all the way). Spray a libral amount on the pintal (pointing looking thing) and then remove the paper clip and start the car. While the engine is running, spray some more cleaner on the pintal and you're done. That's about all you can do to clean it without removing the TB. Then again, removing the TB is piece of cake so long as you don't damage the fuel line o-rings. Heck, probably a good idea to replace them anways and no, the o-rings aren't rare, they're very popular so it's probably a good idea to replace them anyways.
specialized
06-18-2022 09:26 AM
jklein337
09-19-2018 06:23 PM
mdtoren
08-16-2015 05:45 PM
Quick Reply: were is the IAC and how do you clean it on a v-8 camaro
