maybe should of listened to tas
Old Mar 22, 2002 | 11:28 PM
david roush's Avatar
Car: 92'Camaro RS
Engine: a loud one
Transmission: bolted to the engine
Tas threw some ideas at me to get some more power out of my tbi unit. Still i decided to switch over to TPI. So far after 3 days of work i have the intake off and the plastic air cleaner box installed. . Talk about issues . I have been pulling out my hair for three days now. There is alot of work that goes into this. Luckily i have a donor car. I guess i should have gagged a 305 wiring harness instead of one off of an 350 iroc, but i think i finally have everything figured out and in the long run i am sure it will be worth it. After this, it better be.
Old Mar 23, 2002 | 12:00 PM
iroc22's Avatar
Huh dont forget after all that intstallation under the hood you gotta drop the gas tank so you can install the higher pressure fuel pump wahooo
Old Mar 23, 2002 | 05:48 PM
wasp's Avatar
Car: 91 firebird,mint
Engine: 305 tbi,lots of work done
Transmission: 700-r4 built by level 10 in nj
Axle/Gears: 3.73, auburn , precision
ouch
Old Mar 23, 2002 | 07:05 PM
Tas's Avatar
Tas
=/ lets hope it turn out ok.
Old Mar 25, 2002 | 02:14 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Oh I dunno, does gaining 30 HP and 65 TQ at the rear wheels sound worth it? How about running 13.94 @ 98 MPH ? Thats what my dad did after converting is 305 TBI over to TPI, with an LT1 cam.
Old Mar 25, 2002 | 03:44 AM
Tas's Avatar
Tas
ya but David has a 350.
Old Mar 25, 2002 | 06:35 PM
iroc22's Avatar
Its the cam man. You can gain almost 50hp at the flwheel with 20ft-lbs of torque. Oh yeah and replacing the old, tired fuel pump will give u the extra hp, especially at the higher RPM's
Was anything done to the heads?
Old Mar 25, 2002 | 06:39 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
http://web.camaross.com/bb/Forum12/HTML/012570.html
Old Mar 25, 2002 | 07:14 PM
iroc22's Avatar
Thanks man
Old Mar 25, 2002 | 07:17 PM
iroc22's Avatar
10 Rwhp? and the driveshaft was changed to aluminum? That turned out to be miniscule. It seems from the looks of the torque increase that the TBI heads seem to work well with the TPI intake system.
Old Mar 25, 2002 | 07:21 PM
redbird_400's Avatar
Car: 89 Formula Firebird
Engine: 305 - Demon 525
YEah I saw a TPI with manifold on ebay. I bid on it once for 77.00 but then I thougt it would be way to much trouble to do all this + the money I would have to spend on the parts it didnt come with nnnnaaaa!!!!
Old Mar 25, 2002 | 07:38 PM
Car: 92'Camaro RS
Engine: a loud one
This is my last and final hurdle........Anyone have a clue on this one?.... The injection system i took this from was off an 89, 350 IROC automatic... It has a hole in the base which looks like the 9th injector (cold start injector) would fit in there. But i can't find anything on the fuel rail indicating that this has a 9 th injector. And i thought i read somewhere that in in 89' they did away with the cold start injector. Is this the cold start injector?..... and if it isn't is there just a plug that goes into that hole?.... I asked the kid i got it from and he said he took it off about 6 months ago and doesn't remember....Any help???
Old Mar 25, 2002 | 07:52 PM
Car: 92'Camaro RS
Engine: a loud one
Red bird this is where i am at so far.... $500 for injection system (ECM, wiring harness, pleneum, runners, throttle body ,dual fans,wiring harness for fans)...$100 for distributor....$75 for fuel pump w/strainer....$7.95 for 1 bottle of excedrin
Old Mar 25, 2002 | 08:39 PM
ir0cz's Avatar
Car: '89 RS
Engine: 9C1 w/ TPI
Transmission: rebuilt 700R4
I was just about to post the same question. I start my TPI swap this weekend, and I just noticed that hole. I did get what looks like the cold start injector. (got my setup off of an 88 for my 89).
Old Mar 26, 2002 | 05:52 PM
Snowdog 91 Formula's Avatar
Interesting...
I posted this the other day actually hoping a lot of folks would check out the link I discovered!
This is very informative about the EFI systems in our cars. Not just TPI.
I thought you all would like to read this, it's pretty informative all around. Maybe all the boards should see this one.
http://www.fuelinjection.com/portinj.html
I read it and found it very interesting.
And no, it is not strictly about TPI.
I hope it helps answer some questions!
Old Mar 26, 2002 | 07:42 PM
Car: 92'Camaro RS
Engine: a loud one
Several modifications have been made to the TPI system introduced in 1985. The 1985 system used a GM Part #1226870 ECM and had a Mass Air Flow (MAF) sensor and a MAFS module to control the power and burnoff functions for the MAFS. In 1986 two relays replaced the MAFS module and the Electronic Control Module (ECM) was changed to a GM part #1227165. In 1989 the cold start injector was deleted from the system.
Thanks snowdog......i think i got my answer right there...:lala: :lala: :lala: Thanks a ton!!!:hail:
Old Mar 27, 2002 | 05:03 AM
Jza's Avatar
Jza
Your runners should block off that hole..
Old Mar 27, 2002 | 06:13 AM
Car: 92'Camaro RS
Engine: a loud one
runners on.....hole still visable
Old Mar 27, 2002 | 04:47 PM
ir0cz's Avatar
Car: '89 RS
Engine: 9C1 w/ TPI
Here's where I'm at....$450 for setup (ecm, harness, plenum, runners, TB, base manifold, cold start, distributor, fuel rails), $10 for fuel lines, $75 for fuel pump, $5 for new Orings, $30 for ALL the gaskets, $15 for thermostat housing, $14 for TV cable, $45 for kickdown cable.
MitcherNeaf
Sep 24, 2015 09:23 PM
db057
Aug 22, 2015 08:17 PM
redbird_400
Car Audio
Nov 13, 2001 01:31 AM
strokeronthesause
Carburetors
Nov 8, 2000 07:06 PM
