got a raise and need a place to spend the money... haha
Old Apr 2, 2002 | 09:13 AM
NXS055's Avatar
ok, I know this stuff has been covered but I just want some basic info, no major explanations. thanks...
ok, switch to carb? intake and carb? or is more needed? chip? ok
porting heads, i have an L03, is it worth it on the stock heads and what should I look to pay?
if i stick with the tbi what intake should I go with for a good bang for the buck and easy install???
and shift kit, decent shifts, I don't want whiplash but some stiffer shifts is needed, which should I get and how much is it?
I just want everyones opinions about any or all of these points of interest, and lets try not to argue. thanks a bundle
Cody
Old Apr 2, 2002 | 02:20 PM
NXS055's Avatar
i know you guys have opinions on this stuff
come on
Old Apr 2, 2002 | 02:39 PM
Tas's Avatar
Tas
What have you done already? How many miles do you have on the 305? Do you plan on a bigger engine anytime soon? Open element, gears, posi, aluminum driveshaft is a good start.
Old Apr 2, 2002 | 02:41 PM
Mark305TBI's Avatar
Car: '00 Chevrolet Corvette
Re: got a raise and need a place to spend the money... haha
Originally posted by NXS055
ok, switch to carb?
Fuel injection is better than carburetion. Carbs are easier than EFI, though. With extensive modification you will have to tune the chip. I couldn't get mine tuned up with the TBI system so I went to carb.
If you switch to carb, you'll have to swap out quite a few parts. There's a pretty good article in the Tech Central section of this site.
Don't bother porting the stock heads and certainly don't pay anybody to do it for you.
Old Apr 3, 2002 | 07:37 AM
NXS055's Avatar
why not port them, cuz I'm doing the lt1 cam swap in a couple of weeks and was thinking about getting the heads ported while I'm at it. why is it not worth my time or money??? are they that bad???
where can I get a set of decent heads really cheap??? I can't afford upwards of 500 - 1000 for heads, are there any other options???
thanks a bundle guys
Old Apr 3, 2002 | 05:37 PM
iroc22's Avatar
You could maybe eliminate the swirl block right before the intake valve and maybe see a big improvement, but it's a lot easier, if you go cheap, to get a set of LG4/L69/LB9 heads (they're all the same from my hands on experience) and port those guys. The L03 heads can be worked over to perform, but its gonna cost a lot more than picking up a set of the above heads cheap.
Old Apr 3, 2002 | 08:03 PM
PopaPork's Avatar
Extra money?
Here...let me give you my address. If I can have it all in 20s and 50s that would be great in unmarked bills of course.
Old Apr 3, 2002 | 11:32 PM
NXS055's Avatar
i might be willin to trade ya some 20's or 50's for a set of heads mr. pork....
hahaha
thanks for the advice guys.
what should I look to pay for a set of those heads???
Linson
Oct 24, 2025 02:00 PM
ZEEYAA
Apr 16, 2023 08:29 PM
Pac J
May 17, 2020 10:44 AM
RS Reaper
Oct 17, 2018 07:52 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
