How much power can the stock TBI support
Old Apr 8, 2002 | 04:08 PM
bigman's Avatar
In it's stock form with the stock chip, but perhaps with higher fuel pressure, how much power can the stock 305 TBI unit support before it becomes the limiting factor? Then, the follow on question is how much can it support modded before it just doesn't pass enough air?
Dan
'91 RS one-legger w/a bald right rear tire
Old Apr 8, 2002 | 04:13 PM
dmair5_0's Avatar
Car: 91 Firebird
Don't know from experience, I'm still pushing the 200 hp threshold but I've been told that the stock TB can support up to 300 hp before becoming a truly limiting factor.
Old Apr 8, 2002 | 05:47 PM
JPrevost's Avatar
Car: 91 Red Sled
Depends of if you do the ultimate TBI mods, if you run an injector spacer, and what style air cleaner you use. The non-drop base air cleaners are the best.
Old Apr 8, 2002 | 06:30 PM
HrdRockA4305's Avatar
Holley tech support once told me 260 HP. I'm sure it'd be more if you did an injector upgrade. But, at a higher HP level than that, while the stock TBI may be able to support X amount of HP, a bigger one I'm sure would cause you to see a significant gain.
Old Apr 8, 2002 | 10:34 PM
TBI305Camaro's Avatar
most people wont ever even see 260 hp out of a 305 TBI anyways
Old Apr 9, 2002 | 12:04 AM
"most people wont ever even see 260 hp out of a 305 TBI anyways"
Yeah unfortunately that is very true. If I can hit about 220-230 with this motor I've got planned (supa-budget mild engine) I'll be happy. Put a 5 speed and a 3.73 behind it and thats enough HP to hit a 14.0, and honestly if i can hit that I'd be happy.
Old Apr 9, 2002 | 08:17 PM
JokerRS's Avatar
Car: 92RS
Engine: 357
I'm shooting for 300HP without any type of power adder.
BRoss99
Aug 10, 2025 05:08 PM
MustangBeater20
Oct 29, 2022 09:20 PM
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
InfinityShade
Aug 22, 2015 08:00 PM
