difference between TBI spacer and injector spacer?
Old Apr 8, 2002 | 09:04 PM
Black_Widdow's Avatar
Car: 05 GTO, 88 GTA, 98 SS
I made a 1/4 inch spacer to go between the TB and the manifold. I used the gasket as a template. Is this a throttle body spacer or an injector spacer? It seems like it would be called a throttle body spacer. I went on Turbo City's website and they say that their throttle body spacers are 1 inch think and they also sell injector spacers. I guess the injector spacer would be right under the roof of the pod and lift the injector in it's 'bowl' a little bit, right? Should I make my throttle body spacer 1 inch and make a 1/4 inch injector spacer or what? I want to go ahead and do all I can while it's apart. Any help is appreciated!!
Old Apr 8, 2002 | 09:44 PM
91rsrider's Avatar
from what i understand its a spacer that goes between where the injector stack and the TB itself join.i could be wrong,but im pretty sure thats where the spacer goes.hope this helps!
Old Apr 8, 2002 | 10:03 PM
vjo90RS8's Avatar
Car: 2002 Z28
injector spacer: between injector pod and TBI (usually about 1/4 inch)
TBI spacer: between intake and TBI (usually between 1/2 - 1 inch)
Old Apr 8, 2002 | 10:16 PM
Ok, I think I see now.
What I made was an injector spacer, it fits between the pod and the TB base. It's 1/4 inch thick.
Now I need to make a spacer to go between the TBI base and the manifold, and it needs to be 1/2 to 1 inch think.
Will the fuel lines reach the injector pod with the TB spacer?
Will I have hood clearence (stock RS hood)
Thanks!!
Old Apr 9, 2002 | 10:09 AM
scauffiel's Avatar
I had to remove the ring that ran around the back of the "base" in order to get the fuel fittings/fuel lines to work correctly. If you look at the unit, imagine if the fittings were another 1/2" up and you'll see that it's going to hit that "ring".
Steve
Old Apr 9, 2002 | 01:25 PM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
Which one did you make? You said that you made one, then you said you made the other?
Old Apr 9, 2002 | 04:13 PM
91Bird305's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
Make the TB spacer 1/2 inch only. 1 inch and u have to modify ur cable bracket to get the throttle cables to reach.
Old Apr 9, 2002 | 09:32 PM
I only made the injector spacer (1/4 think). I'm going to do the big spacer later, along with the AFPR. I"m just trying to get the car back on the road for now. I've got to change an alternator tomorrow, mine broke
MustangBeater20
Oct 29, 2022 09:20 PM
customblackbird
Aug 15, 2021 10:16 PM
Jae992
Aug 27, 2015 09:07 AM
