best intake
Old Apr 10, 2002 | 02:50 PM
89formula4life's Avatar
best intake
I am thinking about doing the Lt1 cam swap and i figure since all the intake has to come off there anyway... what better time than to put a new one on there soooooo... what does everyone use for an intake.. and what is the best... one more question how much does the intake cost i don't wanna spend too much but i am not cutting corners on this project either so lets hear your oppinions!~!
Old Apr 10, 2002 | 03:02 PM
92RS shearn's Avatar
Car: 92' RS
Engine: LO3
Transmission: Probuilt 700R4
Axle/Gears: 3.70 9-bolt
I was wondering the same thing, I was concidering one of the follwing.
Weiand Stealth
Edelbrock RPM Performer
Edelbrock Jr. Victor
And then use a TBI->carb plate adapter.
Chris
Old Apr 10, 2002 | 05:49 PM
89_Rally_Sport's Avatar
where can you get the TBI-CARB intake adapter
Old Apr 10, 2002 | 08:22 PM
and also by putting a LT1 cam and new intake would I notice much of a difference in 1/4 mile times go.. with whats in my sig + new parts what would be a guess at what i could run(times that is) ....thanks
Old Apr 10, 2002 | 09:28 PM
ttt
Old Apr 10, 2002 | 09:51 PM
Car: 92' RS
Engine: LO3
Holley sells the adapter, I think it was JPrevost who got it for like $11-12 or something like that. I for get the company he got it from. Do a search I'm sure you can find it. It was on a few threads.
Chris
Old Apr 10, 2002 | 10:17 PM
Tas's Avatar
Tas
I got this one. $95. I haven't put it on yet so I don't know how it will turn out. http://www.holley.com/HiOctn/ProdLin...AMSM/7547.html
$12 carb intake to TBI adapter is from www.pawinc.com
Old Apr 11, 2002 | 12:25 AM
Sonar_un's Avatar
Car: '86 T/A
Engine: 350/LT1 Intake
Transmission: 700R4 - Built
Axle/Gears: 4th gen 3.42
I don't see an EGR provision on that manifold. I know NJ Speeder uses a Holley manifold of some sort, and it is emissions legal.
Old Apr 11, 2002 | 12:39 AM
Tas's Avatar
Tas
ya its not smog CA legal. Tims manifold is 49 state legal. It doesn't have CA E.O. number for smog cars.
Old Apr 11, 2002 | 07:57 PM
thanks..so this lil adapter will allow me to fit any carb intake for the small block chevy
Old Apr 12, 2002 | 12:39 AM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
Just a thought, single plane vs dual plane would be a good totw...
I know its come up a few times, but not really recently
Old Apr 12, 2002 | 06:31 AM
91Firecrow305TBI's Avatar
I'm using the Holley 300-36 dual plane manifold. I didn't realize that this manifold was for 1955-1986 heads, so I had to modify the bolt pattern, and run a T-connector off of the vacuum hole to get the brake booster, and the distributer vacuum to work properly. A friend of mine made some sheet metal throttle linkage extenders to reach the old wires. That swap was a PITA. But now that it is done, I am really glad that I did it. The car didn't lose a thing down low, and has really picked up some power up top.
Old Apr 14, 2002 | 11:33 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: best intake
I've run 13s with the following manifold.
Had to cut out the EGR tunnel, and cut back the runner roofs, and the plate cost $20, and then manifold $10.
So I have a total of $30 in the manifold and some elbow grease.
Just some food for thought..
File Type: zip
customblackbird
Oct 1, 2015 04:30 PM
85 Jimmy
Sep 30, 2015 07:56 AM
jerflash
Sep 24, 2015 03:11 PM
toronto formula
Sep 10, 2015 07:31 AM
e3pres
Sep 9, 2015 01:51 PM
