Daring to be different
Old Apr 14, 2002 | 09:19 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Take a XFire lower manifold, stir in a AL plate, a taste of BBC Throttle body, cook mildly with a 747, and you might wind up with something like this.
BTW, it runs really well......
File Type: zip
Old Apr 14, 2002 | 11:07 AM
JoBy's Avatar
Car: 1984 Corvette
Engine: Turbo 350
Transmission: 4L80E with TCI T-Com
Do you know the flow-numbers for that 454 TBI ?
What size are the butterflies?
A pair of stock TBI's flow 570 CFM together.
A Holley 2bbl TBI that has 2" butterflies flows 670CFM according to Holley.
Was anything else done to the intake / engine?
Old Apr 14, 2002 | 11:29 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
The BBC Throttle body uses two 2" butterflies, and depending on model year 80 or 90 PPH injectors. If you're to believe Holley then it flose 670 CFM. The reason Holey uses the 2" butterflies os to have a oem replacement for the BBC applications.
The engine is 355, AL vette L98 heads, cleaned up the chambers, Comp Cams 270, Edlebrock TES, 3" cat back, 80 PPH injectors, my own prom, the XFire manifold has a BUNCH of work done inside of it, crane spark box, lifter valley pan.
Old Apr 14, 2002 | 11:47 AM
JPrevost's Avatar
Car: 91 Red Sled
When you say it runs really well, what kind of performance we talking about here?
Old Apr 14, 2002 | 03:18 PM
DM91RS's Avatar
Car: 91 RS
GRUMP......what are the two components on your fuel lines? Reg and filter?
And.....if I remember correctly reading that you had installed a second muffler where the cat usually resides to quiet down the exhaust? Mine sounds good but....it's several db's too much at times. Did you do something like this?
Old Apr 14, 2002 | 09:59 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
In full street trim, ie big sway bars, stiff shocks, and leaving from an idle ran 13.7s at 99.99. And would do that hot cold humid or dry. And it pulled in high gear just like in 3rd, in an FBod it was lots of fun.
Old Apr 14, 2002 | 10:01 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Russel filter, and Mallory FPR.
Running a 14" ATR Pitbull where the cat was and a 16"(?) Ultra Flow. Those 2 mufflers and 3" pipe makes for a mellow sound.
Old Apr 15, 2002 | 02:21 PM
DM91RS's Avatar
Car: 91 RS
Thanks Grump
Old Apr 15, 2002 | 02:52 PM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
Neat!
I'm working on adapting a 7747/TBI system for my friends '87 Volkswagen ralley car. It should be lots of fun...and lot of TIG welding
By the way...what are the benefits of the x-fire base? Flow?...simplicity?...
Old Apr 15, 2002 | 05:11 PM
JoBy's Avatar
Car: 1984 Corvette
Engine: Turbo 350
You can say that the Cross-Fire is wet-flow TPI. It it a tuned tourqe manifold. Lot's of low and mid range tourqe, and just like the TPI it does not flow enough to make high rpm hp. The TPI can be modified to flow more, and so can the Cross-Fire. The big differance between the two is that the TPI has a lot of bolt-on parts.
Old Apr 15, 2002 | 09:36 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Well depends on which XFire your talking about and high rpm use.
I'd bet you can get a XFire to out flow the TPI.
And there is alot of junk out there for the TPIs.
Old Apr 15, 2002 | 10:00 PM
Car: Bee-Bowdy
Axle/Gears: fo-tins
I see. All the benefits of the TPI intake goals with NO runners...that's pretty snazzy
AND every company that makes ANYTHING for TPI thinks that it's made of gold. Prices for that stuff is rediculous...
Old Apr 15, 2002 | 10:02 PM
Ken73's Avatar
Car: 82 Corvette
Engine: 350 CrossFire
.....the XFire manifold has a BUNCH of work done inside of it.....
Alright, I'll bite. What have you done to the inside of it, besides rip out the EGR, port-match the head area, and grind/smooth the runners?
I've been considering cutting the roofs, and raising them, then hand making a lid out of 3/8" thick aluminum.
Old Apr 18, 2002 | 04:36 PM
DM91RS's Avatar
Car: 91 RS
Grump...I've thought of a couple of questions also...What size air filter is that and did you/are you running the manifold heated water that runs under the manifold to the rear?
myvmax1
Nov 14, 2005 05:37 PM
mikesegar
Sep 25, 2005 01:45 AM
drop-top IROC
Southern California Area
Mar 22, 2005 10:47 AM
Farfire70
Feb 2, 2004 12:22 PM
Tas
Feb 20, 2001 04:44 PM
