GmGoodwrench Crate Engine
Old Apr 16, 2002 | 03:58 PM
Trent257's Avatar
im thinking about buying a car that has a 350 tpi crate engine in it, it was put in maybee 3-4 years ago. any idea what kinda hp/tourque its runnin?
Old Apr 16, 2002 | 04:09 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
If it's this one and that's the one I got here are the #'s and be sure to read the note1 at the bottom.
Gm Goodwrench 5.7 Liter (Universal Engine) Specification
Horsepower¹:
249 HP @ 5,000 RPM
Torque¹:
304 FT/LBS @ 3,500 RPM
Redline:
5,200 RPM
Comp. Ratio:
8.50:1
Heads:
Cast Iron, 72 cc
Valves:
1.940" I, 1.500" E
Camshaft Lift:
Hydraulic; 0.390" I , 0.410" E
Duration @ 0.050":
195° I, 202° E
Block:
4 Bolt Main, 2 Piece Rear Main Seal, 4.000" Bore
Crankshaft:
Cast Iron Nodular, 3.480" Stroke
Spark Plug:
R44TS, Gap @ .035 For Points Distributor or .045 For HEI Distributor
Note¹ - Numbers are for a engine that had a cast iron intake, Q-Jet Carb., HEI distributor, 1-5/8" headers and open exhaust installed prior to dyno testing.
Goodwrench
by the way, the cam in this motor SUCKS.
Old Apr 16, 2002 | 09:20 PM
No4NJunk's Avatar
Car: 87 Grand National
Engine: 3.8 SFI Turbo
Transmission: BRF 200R4
the engine mark just described is the LM-1 engine. This is also what I have. And yes the stock cam in that engine tosses the F'in salad. Those hp/tq numbers are a little higher than the real world application.
Mark, I could swear that the heads have 76cc chambers! Maybe I'm wrong but I'll look into it.
Old Apr 16, 2002 | 09:30 PM
Trent257's Avatar
thanks
but in your description you said q-jet carb, the owner of the car said it had tpi???
also what cam would yo recammend? and how much hp could it add?
Old Apr 16, 2002 | 09:35 PM
Car: 99 Formula
Axle/Gears: 342
Those are the correct CC, TPI might produce a little more power, go with the Comp 268XE
Old Apr 16, 2002 | 09:38 PM
No4NJunk's Avatar
he just installed the tpi on his old engine onto the new 350. Intakes and all will bolt right up. With that setup (tpi like lower rpms) I wouldn't go higher than a 470 lift at .050 and 226 dur at .050. Hp.....a lot over stock. With the proper exhuast system and engine fully tuned expect a good 30 hp just from the cam at least. Beware you are going to be sacrificing torque for this Hp. You will also need a higher stall torque converter
Old Apr 16, 2002 | 11:23 PM
cp87GTA's Avatar
Car: T/A / Grand Am
Engine: 383 SBC
Transmission: glide
Axle/Gears: 9" ford 5.67
There ain't NO stock l98 that has more torque, than a properly preped one with a ex268. I've had to adjust the tv cable, to get shorter 1st gear shifts just to get some traction. Right now I have a 342 open rear, and it'll smoke BOTH tires if you go from a dead stop. Even a stock l98 will benefit from a higher stall converter.
Old Apr 17, 2002 | 12:34 AM
No4NJunk's Avatar
What the hell are you talking about. The l98 was never in the conversation was it??
READ-
Note I said the LM-1 will have more torque stock than with a high lift cam such as the one I stated. Because of the low compression, higher lift, longer duration, and higher rise intake the torque is sacrificed.
Who really cares about spinning your tires. I mean really. If your going to prove me wrong then at least act like you know what your talking about.
When did I state anything about the ex268???
A cam change on an otherwise stock 8.5:1 comp. engine with dish pistons and crap 72 cc heads the torque WILL be sacrificed. We were never talking about an l98. I never said otherwise about the torque being better.
And yes a higher stall converter would help even a stock l98. Again I never said otherwise. We weren't talking about l98s.
Old Apr 17, 2002 | 08:00 AM
Car: 99 Formula
Axle/Gears: 342
Good luck on your rebuild coming soon.
Vintageracer
Jan 10, 2020 05:33 PM
theshackle
Mar 5, 2017 06:37 PM
masonta
Aug 31, 2015 10:14 PM
ezobens
Aug 19, 2015 10:29 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
