timing
Old Apr 22, 2002 | 06:31 AM
myh0's Avatar
timing
anyone know a easy way to fix timing on to 350 TPI?? my car back fires when i rev high any ideas??
Old Apr 22, 2002 | 09:16 AM
Brian Felts's Avatar
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
Set the base first, find the tag on the front of the hood and see what wire you need to pull to set the base timing. Then start the car and set the base timing you can set it at 6* ( I think thats factory setting) or go a little more then turn motor off and then go back and plug in the wire and strart it back up and you should be good to go...........if not there is someting wrong maybe the Dist. Module.
Brian
Old Apr 22, 2002 | 10:59 AM
myh0's Avatar
whoa...i gotta pull a wire? i thought i had to un screw a nut by the disbt. hen turn the dang thing?? lost help!!
Old Apr 22, 2002 | 11:12 AM
Yes its called the EST wire it will then let you set the base. The computer takes over then the wire is pluged in. Then you will loosen the nut and do it old school then turn off the car and plug in the wire and then start it back up and you will be set.
Brian
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
