Rearend replacement??
Old Apr 23, 2002 | 02:21 PM
MX265
Guest
Posts: n/a
Rearend replacement?? The rearend is whining pretty loud. The shop tells me that it is probably the rearend bearings and gears. Is this a terribly difficult job for the at-home-mechanic? The shop tells me it'll be right around $1800.00 to replace the gears and bearings. They make it sounds like some form of mysterious science. If it is, then I don't want to get in over my head.
(Then again, with my luck, I probably don't need a 3500lb car over my head either. )
Any input is appreciated. (Even it is sarcastic input with a touch of humor).
Andy
Old Apr 23, 2002 | 02:42 PM
Spyder's Avatar
Its actually kinda easy. Its all mechanical nothing to hard about it. If you can find someone locally that works on cars, offer him a 12 pack and it wouldn't take more than a afternoon. 1800 is way too high. 500-600 is a good price anything over 1 grand is outragous.
Old Apr 23, 2002 | 03:32 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
It's an exact science, but not mysterious. Special tools required, some experience helpful.
$1800 is "saw you coming" money, though. Look elsewhere, or get an entire used rear for a couple hundred and replace your current one.
Old Apr 23, 2002 | 03:48 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I blew up the posi (gov-lock) in my '84 3.73/posi/disc axle; I bought my "original" axle, a 3.42/open/drum, from a junkyard for $100.
And for $1800 you could buy those special tools and do the gears yourself! Hell, you can replace the axleshaft bearings (misnamed as rear wheel bearings) yourself.
Old Apr 24, 2002 | 06:47 AM
MX265
Guest
Posts: n/a
Thanks guys. This helps. So basicly, $500.00, a 12 pack, a new rear end, and someone with the right tools, I can get it installed. I guess I know what I have to do now. I think you folks just saved a newbie $1300.00. Huge thank you!
Thanks,
Andy
Old Apr 24, 2002 | 08:23 AM
sleeper's Avatar
whoever this guy is...
DON'T GO BACK!!!
and take a moment now to count your fingers
Old Apr 24, 2002 | 06:01 PM
88 427 Camaro's Avatar
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
For $1800 I'll fly down there and do it for you! meaning go find a different shop!!!
Miles
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
86White_T/A305
Aug 17, 2015 12:16 AM
Dan Hubbard
Aug 12, 2015 09:05 PM
marcusaw
Aug 10, 2015 08:13 AM
Fronzizzle
Aug 9, 2015 01:15 PM
