Timing jumping???
Old Apr 23, 2002 | 08:26 PM
Brian Felts's Avatar
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
Timing jumping???
I converted My TBI to Carb Holley S/A 770 and used the Vac advance dist. from Proform. When I put the timing light on the tab (with the vac. line pulled) the timing line will jump from 12* to 6* and back and forth. I used my light on another car and it was fine. What would cause this??? Could I have a defective module????
Brian Felts
Old Apr 23, 2002 | 09:24 PM
ede's Avatar
ede
does it search for idle rpm? is the mechanical advance coming in? bad distributor? air gap on stator wrong?
Old Apr 24, 2002 | 02:12 PM
No it idles fine and there is no change when It does it. It will do it at idle and when I put a little RPM to it. Its all new thats the problem I just can't figure it out. I did use the light on another car and it worked fine there. Think about it and see what you can come up with.
Brian
Infested
May 22, 2018 11:56 PM
1992Vortec
Aug 31, 2015 08:05 PM
EFR2000
Aug 18, 2015 08:54 PM
cstrobel65
Aug 15, 2015 10:19 AM
