Installed new altenator and a weird problem?
Old Apr 25, 2002 | 12:07 PM
twiztidz28's Avatar
Car: 86 Z28
Engine: 355 carbed
Transmission: t-5
Last weekend i installed a new alt. in my 88 TBI which has a serpetine system. Do you guys know the metal piece that holds the radiator hose from hitting the belt? well the belt is rubbing a lil on the piece. I adjusted it the best i could and when I floor it is still rubbs a lil. How can i fix that problem. I also bent the 2 teeth at the bottom and still no luck. anyone have this problem before?
Old Apr 25, 2002 | 03:07 PM
snakeskinner's Avatar
if I understand you correctly you are just having a problem with the upper radiator hose contacting the belt? Can't you just fabricate some sort of rigid bracket to hold it out of the way? What about a different hose that routes it differently.
Old Apr 25, 2002 | 03:16 PM
twiztidz28's Avatar
Car: 86 Z28
Engine: 355 carbed
Transmission: t-5
No it is the bracket that is holds the hose out of the way. I just couldn't think of the word for it before. Its only under heavy loads like when I floor the car and the engine rocks a lil. I am going to try and cut the teeth off the bottom and see if that works.
Ghettobird52
Jul 5, 2024 11:18 PM
rocn7roc
Sep 21, 2021 02:16 PM
Fronzizzle
Aug 17, 2015 02:52 PM
sreZ28
Aug 14, 2015 07:48 PM
TheJoeY88
Aug 13, 2015 06:51 PM
