I failed CO with a reading of 1.47 with low idle, and the limit was 1.20
..............................High speed..................Low speed........
.....................Standard......Current.....Standard..........Current
RPM............................2577..............................615
HC (ppm).........220................23............220...................190
CO (%)............1.20..............0.18..........1.20..................1.47 (FAIL)
CO2 (%).............................12.8...................................12.1
02 (%)................................18.5...................................9.6
On the third page of the print out it says "Explain Rejection Fully: low idle speed to high"
now here is the deal, my Cat is gutted. and has a straight pipe going through it. and i have the AIR pipe connected to it, but i think there is a leak on the air hose, is it most likley the cat causing my problems?? could it be that i need to secure the AIR hose better? is there anything else i can do to better tune the engine so i might pass?? how close am i with the cat not working judging by those readings???
also, timing is pretty far advanced, 93 octane with emmisions pass stuff in the tank. nice and cold today
thanks
thanks
If that's all you missed it by, if you didnt' before, drive the car around for about 20 mins before testing, it helps clean the engine out and helped lower my readings.
well the guy working the inspection redid it about 4 diff times.. failed CO everyone of those times... i also forgot to add that the temp guage didn't get past 180*. would it pass better with a 195* therm or something blocking part of the radiator to get the engine warmer?
wasp
close
- Join DateFeb 2002
- Locationsaugerties new york
- iTrader Positive Feedback0
- iTrader Feedback Score(0)
- Car91 firebird,mint
- Engine305 tbi,lots of work done
- Transmission700-r4 built by level 10 in nj
- Axle/Gears3.73, auburn , precision
- Liked:0 Times in 0 Posts
offer him 2 ben franklins, well one to start
yeah, I think swapping to a hotter thermo may help out, the hotter the engine, the more gas is burned=less pollutants, that is why new cars runs on the brink of overheating.
Another thing you may want to try is shooting a couple gallons of alcohol(not beer or vodka, but pure racing alcohol) into a full tank of gas. Alcohol burns super clean. even putting in a can of "turbo 108 octane boost" may help as that is primarly alcohol.
Or you could just use one bottle on an 1/8th tank of gas. Helped lower my readings.Originally posted by Joshua Leslie
Don't retard your timing - it'll only get worse. The down-side of alcohol is that it burns cooler, so you may need to counteract that by disconnecting the fan or controlling it manually to get the head temperature higher.
If you have an AFPR, try lowering the pressure temporarily to lean it out more. You could even remove a vacuum hose in a discrete location to introduce more idle air, but it may set a code on a MAF car.
How old is your O² sensor?
Had an old Nova that wouldnt pass, one gallon racing alcohol to half tank of gas and drove right through E-check
Quote:
Its about 4-5 months old. Iv been thinking about getting a heated one though..Originally posted by Vader
i have inspection again tomorrow. where can i get some alcohol!?!?!?!
jmd
close
- Join DateJul 2000
- LocationAridzona
- iTrader Positive Feedback100
- iTrader Feedback Score(4)
- Car`86 SS / `87 SS
- EngineL69 w/ TPI on top / 305 4bbl
- Transmission`95 T56 \ `88 200-4R
- Liked:92 Times in 89 Posts
CO was the only thing I had trouble passing after my engine got TPI (w/ the carb, HC was trouble)
A good factory cat helped me fly through inspection, but mine is bolt in so it's a little less hassle to R&R for special occasions
...Supreme Member
Quote:
STP Gas Treatment and most of the "gas dryer" additives are ethanol-based. Read the label, stay clear of methanol...stick with ethanol. Methanol attacks aluminum and rubber.Originally posted by breathment
And put a working cat on it. I like to breathe.
-Kevin
alright, i did some research, your right i do need ethanol.. where can i get SOME!!! and how much should i put in? like how much of those fuel dryer bottles are actualy ethanol??
and as far as the cat goes. Im going to eventualy put one on when i find all my exhaust leaks and save up some $$ fixing more important stuff.. But we have new emissions laws going into effect may 1st, so i have to get it passes with the older ones..
An expensive way to buy ethanol is to visit your local liquor store and purchase Everclear by the gallon.
A cheaper way is to visit your local gas station that sells gasohol (10% ethanol).
Another way is to visit a paint or hardware store and purchase denatured alcohol in gallon cans. It is generally 90% ethanol with 10% methanol added to render it useless for human consumption (drinking it can cause permanent blindness). Methanol is not the best type of alcohol to use in your car, since it can be corrosive to bronze alloys (brass and stuff). In small concentrations, it can be O.K. DeMert's Heet fuel line antifreeze is 100% methanol, so it isn't completely unsafe, just a poorer choice than ethanol.
Go to your local auto parts store, drug store, convenience store, gas station, etc. This stuff is very common. If you want to know percentage ethanol content, read labels.Originally posted by breathment
As close as you were on HC, I'd just go with no more than two 12-16 ounce bottles to a full tank of gas.
alright, found some denatured alcohol under the sink... how much do i use????? i have maybe 8 OZ..
