What is a true sign of a bad alternator?
Old Apr 29, 2002 | 12:15 AM
SlowStangEater's Avatar
What are signs of a alternator going bad. Im still having wierd occurances with my car not charging up after I turn it off. Its wierd.
Old Apr 29, 2002 | 01:24 AM
Omar's Avatar
With the car running, put a voltmeter across the battery. What does it read? A proper reading should be around 13.5-14.4 volts.
Since you have a serpentine setup, it will proably take you longer to drive to your local auto parts store to test it out, then it will to actually remove the alternator from the car. Takes me about 15 mins.
Old Apr 29, 2002 | 06:18 AM
Jza's Avatar
Jza
The "true sign of a bad alternator"? Constantly having to jump-start your car.
Typically, a car won't charge after you turn it off. Not weird at all.
Anyway, I'm just being less than useful because Omar pretty much said it. 13.5-14.4 volts with car running. Anything less=bad sign.
Old Apr 29, 2002 | 08:22 AM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
If you meant that you are losing a charge when you leave it sit, the proper way to track that down is through probing your harness and fuse panel until you isolate the offending circuit.
Old Apr 29, 2002 | 09:02 AM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
some parts stores will do an on car check for free. we did this at murray's discount auto when i worked there, the diagnostic tool would check the battery, starter and alternator and it was really accurate with diagnosis.
Old Apr 29, 2002 | 03:41 PM
z28onTweenkies's Avatar
Car: 1992 Camaro Z28 & 2k3 Cadillac CTS
Engine: LB9
Axle/Gears: 3:43
haha mine is dying and it sounds like a supercharger, so that is one sign.
Old Apr 29, 2002 | 05:06 PM
Thanks guys!!! Im hoping that its just heat soak but I will find out this week.
Old Apr 29, 2002 | 05:23 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I always use the voltmeter too... engine off = 12 volts, engine running = what Omar said.
Also- something odd on my '86 Firebird- it has a battery light. Know how all the dash lights come on when you turn your key to "on" before you crank the engine? Well, if this dumb battery light is NOT ON, it means the alternator's regulator has fried. Stupid, eh? Who looks for a MISSING warning light? Argh.
A common failure for my year of alternator (mid 80's) is rear bearing failure due to overheating. One alternator that died was throwing sparks! "What's that noise? I'll pop the hood- oh s%#*!!!"
Old Apr 29, 2002 | 05:43 PM
Fast3rdGen's Avatar
easy free check you can do yourself
with the engine running....disconect the battery......a good alternator will keep the motor running....if it's bad it will die as soon as you pull the connection.
Old Apr 29, 2002 | 05:48 PM
Re: easy free check you can do yourself
does it matter - or +???
Old Apr 29, 2002 | 06:04 PM
Car: '87 Camaro LT
Engine: 355 L98
DO NOT DISCONNECT THE BATTERY!!!!!!!!
this is no longer an acceptable method of diagnosis, it can screw stuff up bad. i can't remember the specific details but i know you're not supposed to do that
Old Apr 29, 2002 | 06:08 PM
snoozeyaloose85's Avatar
Hold a screwdriver on the back and see if it is magnetized
Old Apr 29, 2002 | 06:10 PM
89Formula305's Avatar
my freind has such a good charging system in his 84 camaro that you turn off the car and the radio will keep going for about 45 seconds...
Hotrodboba400
Dec 10, 2019 07:07 PM
Blue419
Sep 10, 2015 01:03 PM
64goatman
Sep 9, 2015 01:09 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
masonta
Sep 1, 2015 06:40 PM
