HEI problems
Old May 5, 2002 | 09:00 AM
cdogc350's Avatar
HEI problems
Hey, lets see if someone can help me with this one. ive got a 1987 with a 383. one day my i went to my car to start it...it cranked and cranked with no start. ok no problem, ive been a technician for quite some time now, sounds like no spark. so i check for spark and obviously there was none. Its got power to the coil. ok so i pulll the dist. off. and check everything out. coils got the right ohms everything seems to be connected correct. dumfounded i put it back together and it fires right up. ok, so maybe i missed something and i put it back correct again. a few days later it shut off on the highway?? i take the dist. apart and reassemble on the shoulder. it fires right up. i then went and picked up a new cap and rotor. works fine for a few weeks...then it happens again. im kind pissed now so i went and brought a whole new dist., cap rotor, new coil(i was running a accel supercoil, i got the same one again), wires, and plugs....a whole new ignition. for months it didnt happen, so i figured it was a bent or loose shaft shaking the crap out of the dist. if you didnt guess already it happened again? any input? the whole damn setup is new? the wires run straight from the battery with no resistor could the coil not like a full 14 or so volts? It kinda hurts when your a technician and you cant fix your own car.
Old May 5, 2002 | 07:39 PM
Hellraiser's Avatar
Re: HEI problems
Originally posted by cdogc350
so i went and brought a whole new dist., cap rotor, new coil(i was running a accel supercoil, i got the same one again), wires, and plugs....a whole new ignition. [/B]
You didn't mention the ignition module, did you replace that as well?
Hellraiser
Old May 6, 2002 | 09:45 AM
cdogc350's Avatar
The new dist. came with the module
Old May 6, 2002 | 09:53 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Sounds to me like a bad connection in your custom wiring somewhere.
Old May 6, 2002 | 11:02 AM
TBI305Camaro's Avatar
hey since your a tech can you tell me how to test my to see if my distributer is bad...im getting no spark anywhere...not even to the cap...i replaced the igniton module and the coil pickup or whatever it is...the pickup was fried but still no spark anywhere...maybe the coil?? i dont see how tho because the coil is brand new from hypertech but i guess that could be it...what do you think?
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
86CamaroDan
Sep 29, 2015 10:08 PM
andy74
Sep 3, 2015 08:41 AM
GeneralIesrussi
Sep 3, 2015 03:23 AM
greenyone
Sep 2, 2015 03:39 PM
