Sound Clips
Old May 5, 2002 | 10:34 PM
SlowStangEater's Avatar
Sound Clips
Does anyone have any sound clips of their engine and exhaust??
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
There's a bunch on the home page, and check out the exhaust board. Mine is in my signature.
Old May 5, 2002 | 10:35 PM
I cant open yours for some reason........Its not compatible with Media Player........ Let me try again though.
Old May 5, 2002 | 10:37 PM
Car: 99 Formula
Axle/Gears: 342
Should be, it's a wav file.
Old May 5, 2002 | 10:55 PM
I could only see the road video one. Were you holding the camera yourself??? If so you are pretty damn talented...
Old May 6, 2002 | 07:52 AM
Car: 99 Formula
Axle/Gears: 342
Yes, I was holding the camera, but you couldn't get the sound clip to work.
Old May 6, 2002 | 09:21 AM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
here
idle
rev
edit
both links should work now.
Old May 6, 2002 | 09:53 AM
Car: 99 Formula
Axle/Gears: 342
Re: here
Originally posted by jcb999
idle
rev
What kind of exhaust are you running?
Old May 6, 2002 | 10:17 AM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
hooker supercomps - dual 3" into 4" mufflex
takes some work to get decent ground clearance and not too cheap.
Old May 6, 2002 | 10:57 AM
Car: 99 Formula
Axle/Gears: 342
I get errors when I try to save or open it.
Old May 6, 2002 | 11:30 AM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
uv got mail
... if yahoo allows 1.5meg attachemts..
Old May 6, 2002 | 11:50 AM
gruveb's Avatar
Car: 1989 IROC-1
jcb999,
The idle link works, but not the rev...whatupwitdat?
Can you send it to me at brownie@theriver.com?
Thank you
By the way, the idle sounds TOUGH!
Old Jun 11, 2002 | 09:24 PM
wingnut's Avatar
Car: '91 Firebird
Engine: 408 SBC
Re: hooker supercomps - dual 3" into 4" mufflex
Hey jcb999, what type of gound clearance problems did you run into? I'm curious because I just ordered what I think is the same setup you have - Hooker Super Comp Headers (1 3/4" x 28"), Mufflex 3" Y-pipe into single 4" exhaust pipe with Spintech muffler into single 4" hideaway tailpipe. Maybe your experience can save me some grief. Also, did you opt for the Flowmaster or Spintech muffler with your system? (sounds great either way).
BTW, my Mufflex system will be going on my '91 Firebird - I'm installing a 430HP SB Chevy 400.
Old Jun 12, 2002 | 08:01 AM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
the Y pipe is a real bear to put on right
Its really 6 sections of pipe that have various curves each that have to be at the perfect angle to give maximum clearance. The Y (actually the seventh piece), is really not the problem. ITs the head pipes and the sections that go under the crossmember.
the best thing to do is get the crossmember sections to be within about .5 inch of the crossmember and you will have about 3inches.. not much more than that though.
Its a flowmaster 4" two chamber race muffler.
thanks
Supercomps are already rusting even though they were coated..
Old Jun 12, 2002 | 04:25 PM
wingnut's Avatar
Car: '91 Firebird
Engine: 408 SBC
Thanks for the info.
I didn't realize the Y-pipe came in several pieces. I was hoping that I could clamp the kit together and have it welded up at a muffler shop. Looks like I'll be driving to the muffler shop with open headers, instead.
Old Jun 12, 2002 | 11:38 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
What exaust setup do you have?
Old Jun 12, 2002 | 11:49 PM
wingnut's Avatar
Car: '91 Firebird
Engine: 408 SBC
Old Jun 14, 2002 | 05:16 PM
camarokev400's Avatar
hey jcb999
That car sound real tough with that exhaust, what are you running for a motor? it sounds pretty built whatever it is.. I kinda wish i would of done something like that after hearing yours, ive got a 3 inch cat-back flowmaster american thunder with hedman headers hooked up to a 406 small block chevy, havent got it all together to hear it yet though.
Old Jun 14, 2002 | 07:50 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
its a 400 with brodix track 1 heads and a cammotion hydroller
The Y pipe comes with some wide clamps that help locate it but its still a pain.
my motor
I have not had it on the dyno yet..but it really does not run like it should. It just does not pin you in the seat. but.. i think I might have overgeared it with the 4.10s.
I have just purchased two different intakes and it will be going to a dynojet soon and maybe to an engine dyno shortly after that.
Its about 10.8 to 1 with a flat top, with a lightweight rod and piston. The cam is about 238 intake-596" lift and 247 ext with 603 lift on a 109lsa.
thanks
Old Jun 15, 2002 | 07:34 PM
EvilCartman's Avatar
Car: '82 Z28
My setup , mic was about 2 foot away pointing away from the car a bit. Exhaust specs in the sig not including the cat. Highest rev was 5,500 rpm
RS Reaper
Oct 17, 2018 07:52 PM
Night rider327
Feb 25, 2016 09:50 AM
wanext
Oct 6, 2015 12:18 AM
Fanatic1074
Oct 2, 2015 03:47 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
