Out of gas???
Old May 8, 2002 | 03:19 AM
Jyrx's Avatar
Car: Firebird
Transmission: th700
Out of gas???
I have had a lot of trouble with my gas gauge lately or maybe it is something else!? OK My gauge reads that I should have at least 10 Leaters of gas left but my car suddenly starts choaking and dies !
When I try to start it up it starts again and works fine but when I shift in gear it USUALLY (Not always) dies again. I was able to drive like this for 10 miles the other day before I got to the gas station. What gives?! Im thinking that there is something wrong inside the tank .
Help please this really sucks!
Old May 8, 2002 | 03:38 AM
titeride85's Avatar
Well, it could be a few things. My bet would be on either a bum float in the tank giving you a bad reading, or you have a plugged fuel filter.
Is if fuel injected or carb? You could have clogged injectors starving you motor. If you get to much air (which happens when you are moving) versus fuel, it wont fire right and will die. Just a few things to consider.
And for the American standard, 10 liters is approx. 2.5 gallons. Correct?
Old May 8, 2002 | 06:02 AM
Jyrx's Avatar
Car: Firebird
Transmission: th700
Sorry It is a 350 with a carb.
The fuel filter is OK.
It just happened again during my lunch brake And I cant be out of fuel!
And yes I guess 10L is about 2.5 gallons.
Old May 8, 2002 | 06:28 AM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
could be an ignition problem also.....maybe the spark control modual....
Old May 8, 2002 | 10:05 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Re: Out of gas???
Sorry this is off topic, you're from Estonia? Last year in college my Economics teacher was like obsessed with that country, always had us doing assignments on it and watchin videos. Sorry had to throw that out there.
Old May 8, 2002 | 11:43 AM
cfabe's Avatar
Remember that while none of the factory gauges are all that accurate, the gas gauge is probably the worst. If its reading that you have 10L left, you really might be running out of gas. If as soon as you fill up the tank the problem goes away, then I'd say just dont let it get quite that low.
Old May 9, 2002 | 12:37 AM
Jyrx's Avatar
Car: Firebird
Transmission: th700
Thanks for your all your help. Im gonna try to keep more gas in the tank then!
Oh and Mark A Shields you must have a pretty cool eacher !
I bet he/she did not make you do any assignments on f-bodies in Estonia because there are like 20 of them over here And there is like one more on the island I live, so good help is hard to get!
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
KCG
Jun 24, 2020 04:33 AM
86maro_252
Oct 10, 2015 06:52 PM
kx3g
Sep 28, 2015 08:14 AM
reactor60
Sep 22, 2015 01:44 PM
